| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I'm looking at buying a TDA1541 dac kit and would be grateful for some advice. The schematic shows two opamp stages for each channel. Is this optimal? Could the scheme be simplified/improved?
Thanks in advance :-) |
#2 |
Could I just replace the output stage with this simple stage from the datasheet?
#3 |
My philosophy is the simpler is the better. You can get rid of the 2.2nF capacitors, as well. The next step will be to go for no-oversampling (removing the SAA7220), then rolling the opamps... This is a never-ending game.
Don't forget the output of the opamp will be at DC so a blocking capacitor is needed. It is in the signal path, so... |
#4 |
The first schematic I posted is incorrect - here is a corrected version:
#5 |
I plan on using LME49710 opamps instead of the OPA2604 shown.
Would sound quality improve if I just use one opamp per channel without the 2.2nF cap? What is the second opamp on each channel for? Is this a low pass filter for rolling off the >20KHz digital rubbish? If so, I think I can live without it (I'm used to TDA1543 non-oversampling dacs without filtering). |
#6 |
Magneto the Gravity Man
First opamp is the i/v converter, 2nd opamp is the lowpass filter.
Improve the power supply - separate the analog and digital 5v etc Replace the clock with a better version Use a tube i/v and output Where do you stop?? Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#7 | |
Also, I implemented NOS and it sounded awesome, but it sounded much better when I added an SAA7220P/B. But this was a DAC, not in situ, in a CD player, so my recloking was perhaps different. Sorry, Oshifis, I very rarely disagree with you! But, there's loads you can do
#8 |
If you are doing any mods and component changes around the output OpAmps and filters than at the very least you have to do some simple measurement's to back up the changes, even if it's just a 20-20khz sweep from a test CD to make sure you havn't altered the response.
Have a read at Marantz CD50 Mod that is just stunning Post #10 I actually measured the effects of this one. |
#9 |
My inclination would be to drop the SAA7220 and low pass filter stage, to give a non-oversampling dac with active I/V (LME49710).
Any thoughts? |
#10 | |
The schematic shown in post 4 does not use the SAA7220 and so is already NOS. Andy
| Connection of I/V stage to TDA1541...? | Skorpio | Digital Line Level | 3 | 20th September 2007 05:31 PM |
| Yet another output stage for TDA1541 | mevangel | Digital Source | 6 | 21st November 2004 08:21 PM |
| TDA1541 + I/V Output Transformer | mrstone | Digital Source | 10 | 17th April 2004 02:19 AM |
| How many TDA1541(A) in parallel without output baffer? | iklari14 | Digital Source | 0 | 7th August 2003 11:34 AM |
| First DAC project ,TDA1541 current output | George Kubitsch | Digital Source | 8 | 6th December 2002 04:30 PM |
