| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
Excellent work Koon! Is there a way to get this working so you could stream any audio source in? For instance, I have two sound cards. One soundcard takes any external audio - analog signal/digital signal, and sends an SPDIF signal to the second sound card. The second sound card applies realitime FIR crossover and channel delay to that incoming S/PDIF signal. So, in essence, I can listen to anything realtime - TV, sports, movies, and of course music., I just need to hook it up to the first sound card.
#12 |
Hi tschanrm, actually I don't have full knowledge of multimedia streaming, but it will be convenient.
(1) Output stream : I don't have to keep huge 8 channel wave file. (2) Input stream : selectable for stored WAV file, or external input. I wonder there should be many "multimedia programmer" skilled than me but no contact or feedback yet. Maybe stream handling will be difficult than file handling, but sometime I hope to study / implement.... |
#13 |
Hi folks.
When it comes to routing flexibility Linux respectively ALSA lets you do quite some weired stuff: http://alsa.opensrc.org/SurroundSound The questions remains if I can address and send data over HDMI Tx ch0 to RX ch0, Tx ch1 to Rx ch1 asf. And on the Rx side map Rx0 to Amp0, RX1 to Amp1.... @Thomaseliot: There you can also read how to route from stereo .wav to multichannel. Cheers
::: Squeezebox Touch Toolbox 3.0 and more ::: by soundcheck |
#14 |
I uploaded test tone wave file, to make it easy to test your environment can play 8channel audio.
CH1,2,3,4,5,6,7,8 = { 200, 400,600,800,1000,1200,1400,1600 Hz} Playing in Loop mode, attaching single speaker to each speaker terminal of AV Amplifier.. easy to check 8 channel is played or not. and source code to make this wave file is also available. http://koonlab.com/MultiAmpForEveryo...DMI_AVAMP.html |
#15 |
BTW:
Auzentech and Asus coming up with 8*LPCM over HDMI PCI soundcards. http://www.bit-tech.net/hardware/200...tex-2008-psp/1 http://www.xpmediacentre.com.au/comm...by-truehd.html
#16 |
The wonderful audio Swiss Army knife SoX http://sox.sourceforge.net/ provides LOTS of functions, among them merging audio files to create multitrack outputs. Works fine on windows too. You may find it useful just as I did
And btw writing a new effect module is pretty simple, sox just passes x-dimensional arrays of long ints, all the format conversions and the other stuff taken care of.
#17 |
Koons fir-engine output could be piped realtime into Sox, which outputs the multichannel-wav over HDMI?
Is this your idea with Sox?
#18 |
Well, I do not know about piping multiple streams through sox on windows (I guess not feasible), I think Koons FIR engine produces multichannel output directly.
#19 |
Koon is using a multichannel .wav and not mutiple streams as far as I understood.
#20 |
Perhaps an ideal solution would be
Audio app -> Jack -> Koon's FIR engine -> Jack -> HDMI out Jack is available for Windows and OSX now as well as linux. I wonder if Koon's FIR engine is suitable for realtime processing of streams? Possibly it could be ported to Linux and OSX as well. |
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 08:29 AM |
| Multi purpose multi channel gainclone PCB: Team project - group buy | rick57 | Chip Amps | 14 | 29th March 2003 06:54 PM |
| multi-channel AMP? | JAZZ2250 | Solid State | 1 | 15th September 2002 10:10 AM |
| Page generated in 0.11415 seconds (84.68% PHP - 15.32% MySQL) with 11 queries |
