PCB design for TDA1541 - noob needing tips
Old 3rd May 2008, 11:06 AM   #1
Painkiller is offline Painkiller  Norway
Default PCB design for TDA1541 - noob needing tips
So... I'm not very good at either electronics- or PCB design, but I do a little diy on a very amateur level. Self taught.
To avoid using a breadboard I thought I could make a simple PCB for myself. It's for a TDA1541A NOS dac. The schematic is the standard one with 100nF decoupling and 470pF for the oscillator. Regs are meant to be shunt, so there's no need for caps on input or output. The cirquit on the left is something proposed in another thread here on diyaudio, for slowing down the clock signal. Silk screen is not important, as I won't be using it anyway.
The pic shows a photoview from top, with the dark traces x-rayed through from the bottom layer. The light green is the ground plane on top layer.
I was looking for comments and suggestions for improving the PCB.
PCB design for TDA1541 - noob needing tipsHide this!Advertise here!
Noob needing sub for gigs. mrbobian Subwoofers 20 7th May 2008 10:57 AM
proaudio dipole, tips/design? thadman Multi-Way 2 19th April 2007 12:15 PM
Newbie Needing Project Design Advice cwoodall Everything Else 1 23rd August 2005 05:27 AM
Noob - Needing help deciding what Gainclone design to use tsnyder41 Chip Amps 5 20th May 2003 12:54 AM
