Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st April 2009, 05:27 PM   #21
anbello is offline anbello  Italy
anbello's Avatar
Originally posted by peufeu
In order to slave your CDP you will need to transmit the clock. I suggest either fiber optics or differential lines. Optic transceivers will not handle 16 MHz though. Both allow you to separate the grounds. For differential you could use a very cheap Ethernet transformer from DigiKey since both clock and SPDIF are transformer-friendly). Coax isn't good for this because the shield needs to be grounded at both ends, or else it makes a very effective antenna, differential is much better. Ground the shield at one end only.
You can use bit clock instead of master clock to slave the CDP and multiply by four (at CDP) with this so common TOTX, TORX and fiber optics would suffice at those frequencies.
Ciao
Andrea
Old 21st April 2009, 08:11 PM   #22
Jambo is offline Jambo  United Kingdom
Chris,
I have plenty of WM8805s, drop me a PM and we'll sort something out - in the UK for a couple of weeks from now.
Cheers
Jamie
Old 24th April 2009, 09:03 AM   #23
yangsmm is offline yangsmm  South Korea
Default What about cs8416?
What about cs8416?
many recoomend wofson, but cs8416 is also good for personal user^^
Old 30th April 2009, 10:46 PM   #24
Default Cheers Jambo
That would be great, I'm only looking for a small number. I'm allowed to use the pcb etching and surface mount kit at work for personal project as long as I only make a few (aka not a commercial side line).
One small rinkle. I'm still a newb on this forum an hence cannot send emails to users yet, something to do with the number of posts I have made, any chance you could drop me an email and then we can sort something out.
What sort of price were you thinking for per chip?
Thanks again for all the help.
Cheers
Chris
Old 11th May 2009, 11:27 PM   #25
tomper is offline tomper  Poland
Default To Jambo
Jambo I need some WM8805 and pcb for your dac. Send me email inforq@gmail.com
PC as source and SPDIF connection to the external DAC jarthel Digital Line Level 1 4th June 2009 04:31 PM
CD PRO2M - SPDIF for external DAC sandy Digital Source 2 6th September 2007 03:01 PM
Add external Clock to CS8414 hktcm Digital Source 5 12th October 2006 01:04 PM
Dac with external clock how and why?? kimschips Digital Source 3 9th August 2005 11:19 AM
External Clock Signal - HOW? cartman Digital Source 1 9th June 2005 02:06 PM
Page generated in 0.08785 seconds (76.49% PHP - 23.51% MySQL) with 10 queries
