| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#41 |
Any further advance with your cuda based fir program? Would be great if there is....
I'm reaching the limitations of brutefir as it doesnt want to play ball with the latest versions of netjack2 (look it up if your into having a seperate linux dsp box and the idea of multiple soundcard clocks keeps you up at night).... |
#42 |
Nothing for this project (for, HDMI output)
I bought Atmel NGW100 and thinking to use it as output device. 8ch PCM data packet -> NGW100 -> ALSA -> AC97(44.1kHz) -> FPGA -> 4 way I2S. it will take some months to complete |
#43 |
Any progress on this front?
I believe Klein and Hummel has adopted FIR technology for some of their more expensive studio monitors and I might go that way but the price is very high. Is there a solution we could rig up ourselves? |
#44 |
Is there anybody using Cuda FIR based crossover on Linux?
#45 |
progress or changes: I made ASIO output and so far satisfied now.
on Linux: ASIO can be used on Linux? then some possibility.. CUDA Real FIR simplified by ASIO |
#46 |
That's awesome... sound processing in the videocard
#47 |
ASIO is a win32 api. If someone intrest on GPU powered FIR on Linux, then he/she should choose one of cross platform APIs like libao (Xiph.org: libao: a cross platform audio library) or native ones like alsa, pulse or jack.
#48 |
#49 | |
#50 |
This one is using PortAudio, to HDMI
Multi Amp for Everyone This is PortAudio to ASIO driver. CUDA Real FIR simplified by ASIO So Linux people need some multi channel output, can be used with PortAudio. |
| tube basics: computing mu and transconductance | jarthel | Tubes / Valves | 11 | 31st January 2012 11:15 PM |
| Questions Computing Baffle Step Compensation circuit | chasingame | Multi-Way | 10 | 6th August 2009 07:51 AM |
| Computing or measuring anode curves w/ CFB | Tubes4e4 | Tubes / Valves | 3 | 19th May 2009 10:31 PM |
| Computing question: VPNs | trwh | Everything Else | 2 | 1st November 2004 11:25 PM |
| Page generated in 0.10295 seconds (75.37% PHP - 24.63% MySQL) with 11 queries |
