Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th December 2003, 02:05 AM   #11
moemoe is offline moemoe  Singapore
Hi All,
My implementation of the DEM relocking is finally working and it complement my tda1541-based non-os dac (which I also recently completed, I will post a new thread on my DAC soon ) very well. Mr Henk Ten Pierick has kindly replied me on the questions I raised in my previous post. below are his comments:
"The output signals at Q0 and Q1 are the same because their inputs are also connected together. The output voltage of Q0 and Q1 is the same, therefore the outputs can be connected to each other and is equal to the supply voltage of the latch. The parallel connection does not influence the output voltage but doubles the available output -current-, there is more drive current. This is beneficial because we want to drive the pnp transistors."
my implementation differs slighly from the original schematic - 1) I'm reclocking bck instead of ws. 2) the divided freq is derived from Q5 of 4024 (4*Fs) instead of Q4.
Right now, I just want to sit back and "rediscover" music. When I get around to doing some more mod, I intend to try out the following:
1) replace 74hc4024 with 74vhc4040 (dont think there's a vhc version of 4024) - to reduce propagation delay of divided freq.
2) replace 74hc04 with 74vhc04. reason as above.
3) replace 74hc174 with 74vhc374 and reclock all 3 lines (data, bck & ws) together with the required current drive for the pnp transistors.
4) try 8*Fs for non-os application?
Best regards,
Moe
Old 16th March 2004, 07:57 PM   #12
Zodiac is offline Zodiac  United States
Default PH2369??
Quick question... I am looking to implement this DEM reclocking circuit. The diagram at the start of this thread indicates a ph2369 transistor. This is an NPN transistor, not a PNP as indicated on the diagram.
Could someone confirm this, and suggest a suitable PNP to use?
Thanks!!
Old 17th March 2004, 08:27 AM   #13
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Default Re: PH2369??
Originally posted by moemoe
Hi All,
Did you compare 4* against 8* DEM reclocking moemoe ?
This is a typo on Henk's schematic.
I just used generic PNP's like BC557B
Rudolf Broertjes
Old 19th March 2004, 06:00 AM   #14
no. I haven't got the chance to do any comparison yet. Right now, I'm busy with my home renovation. I may do so when the reno is complete in the next 2-3 months.
I'm pretty much satisified with my 1541 implementation. however, i do notice that, from time to time, noise always creeps into the music. the noise is the hissing type that fluctuates with the music. changing orientation of the 3-prong plug, conntecting a piece of copper wire from the rca ground to the chassis and moving the interconnection cables seem to help eliminate the noise but sure enough the noise is again there after a few days, sometimes even lesser. I believe I have either a ground loop issue or my dac ground wasn't implemented correctly. If anyone has a solution to offer, bring it on! I will appreciate it very much. I intend to seriously look into this issue before I start on my second dac project (based on 1543 this time round) in the next few months.
Thanks!
Old 21st March 2004, 09:54 PM   #15
DEM recloking working!
I have implemented this in my non os TDA1541 S2 dac (pictures will follow sometime....) along with reclocking of Fs, Bck and Data using a 74VHC373 as suggested by moemoe. I am using a Tent XO to generate a free running clock and using 74HC163 synchrous dividers to send Fs and 64Fs to the CS8412 receiver. As suggested by rudolf, generic PNPs were used for the DEM reclocking. Everything as usual P2P wired on perfboard.
Overall, the reclocking and DEM mod have made a substantial difference to overall sound quality. First was the I2S reclocking, then the DEM mod. Both mods take the sound in the same direction, if anything the DEM mod made more of a difference than the I2S reclock.
Subjective listening comments:
Positives:
1) Significantly improved dynamics and transient definition e.g. plucked guitar strings
2) Much tighter bass, drums have impact now e.g. those on the opening to Dire Straits 'Money for Nothing' rather than being flabby and loose
3) Cleaner highs, esp. female vocals. Norah Jones voice has taken on a whole new dimension!
Negatives:
1) Sound stage seems to have narrowed in both width and height, this may however simply be a result of instruments being locked better in space
I had compared my TDA1541 S2 dac (before I2S reclock & DEM mod) to a Doede Dac (multiple TDA1543) and although the S2 was preferred for capturing the texture and tonality of instruments, the Doede was much better in terms of dynamics and solidity of instruments, especially in the bass region. Now I would say the S2 is equal to the Doede in dynamics and bass but much better in capturing textures and atmospherics, also vocals much smoother.
These comments are all based on feeding both the XO and logic circuits with a non-optimised 317 regulator. When I get a moment I will put a proper power supply in, I'm leaning towards Jung reg for the clock and current sourced 431 shunt reg for the logic.
Old 4th April 2004, 10:35 PM   #16
guido is offline guido  Netherlands
guido's Avatar
After some mails with Henk about why he reclocked WS, the conclusion is (with an I2S player, e.g. the 960):
Reclocking of BCK is most important (in and output latches are clocked on BCK) and reclocking WS and DATA is beneficial too.
Reclocking of the DEM clock before the transistors is done for removing jitter introduced with the 4024.
I'm going to implement it too, but i have to do two dac's , so it might take a while.
Greetings,
GuidoB
Old 4th April 2004, 11:02 PM   #17
Bricolo is offline Bricolo  France
Bricolo's Avatar
Greetings,
Guido,
What is a latch? Is is the instant when the DAC reads the input data (or outputs the analog data)?
And can't reclocking one or 2 of the I2S lines cause problems, since there will be a delay between them?
Old 5th April 2004, 12:49 AM   #18
guido's Avatar
Now looking at the logic used.
A standard 4024 is slow, so you need to invert the clock of the '174. Otherwise the '174 would be clocking in and the 4024 hasn't clocked out yet....
delay of the 4024 is 50/60 nSec. 11.2896MHz is 88nSec, so 44nSec between clock high to low and low to high. With the
inverter you get 88nSec+inverter delay for the 4024 to output the data instead of 44nSec which is not enough.
So don't use a superfast 4024, say with a delaytime which matches the inverters delaytime. The 4024 would be clocking out while the '174 is clocking in... And the '174 needs some time that the data needs to be stable before clocking.
Faster logic isn't always better
Or if you use a superfast 4024 you could remove the inverter in the clockline of the '174. The 4024 then has 44nSec minus the '174 setuptime for dataoutput.
Fmax of a 4024 is typical 10MHz at 5V, that is less then 11.2896 And minimal is only 5MHz
(looking at philips datasheet of standard CMOS HEF familiy).
Anyone looked at this? Which logic are you using?
Greetings,
GuidoB
Old 5th April 2004, 05:02 PM   #19
Hi Guido,
Re the logic question...If you use syncronous dividers such as the 74HC163 then delay becomes much less of an issue compared to binary counters like the 4024 / 4040. I am using these without an inverter on the clock line to the flip flop.
Rgds.
Old 5th April 2004, 10:22 PM   #20
guido's Avatar
Hi Guido,
Rgds.
Thanks,
You have confirmed my thoughts. I'm going to look what i can get easiest/cheapest on logic. Wanna try and find a FF with inverting output (like '74) so i can do without inverter all together. But maybe i'll put it together the way Henk did. As long as i understand what is going on mmm sortof
mvg
GuidoB
Reclocking in a TDA1541 (zero-oversampling) CD player Dr.H Digital Source 13 4th June 2010 08:35 AM
Decoder output: how jittery, worth reclocking? And "double" reclocking hollowman Digital Source 0 17th July 2009 02:39 PM
Reclocking to tda1541 pc board weegs Digital Line Level 0 13th May 2008 12:45 AM
What is the max reclocking frequency of the TDA1541 Dac gaetan8888 Digital Line Level 1 13th September 2007 01:48 PM
Reclocking diyman Digital Source 1 17th November 2006 02:03 AM
Page generated in 0.14685 seconds (81.78% PHP - 18.22% MySQL) with 11 queries
