Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th March 2008, 01:34 AM   #11
kevinkr's Avatar
FWIW, and I am not totally sure about this, but I suspect the diode from the input circuit back to the input is reversed. Simulations indicate it works much better that way, but overall I'm uncomfortable with this circuit - I think a high performance comparator might just be better.
The Zhaolu 2.5A I have been tweaking uses a very similar input receiver, and I suspect its performance leaves something to be desired particularly at higher sample rates where the performance of the dac seems to degrade. This is idle conjecture, until I get in there with my scope and look around I can't say for sure.
www.kta-hifi.net
Old 4th March 2008, 01:41 AM   #12
kevinkr's Avatar
Originally posted by leon
I'm still expirimenting so I'm not confident enough to publish my design.
If you noticed I use 74HCU04 but I also included a voltage comparator to expiriment with in the input stage.
You might want to consider sharing it anyway, some of us might see things that you can improve and we might also learn something as well.
Somewhere around here is my old dac thread, the dac unfortunately was stillborn.. I'm currently tinkering with the Zhaolu and buying some boards from Twisted Pear Audio. Their spdif receiver module uses the Wolfson WM8804 spdif transceiver module which is both a rather good receiver and includes a transmitter module - it can even be used for reclocking the spdif data stream if desired.
www.kta-hifi.net
Old 20th November 2008, 09:38 PM   #13
theAnonymous1's Avatar
Does anyone have any updates on their project?
I would also like to build a DAC with DIR9001->PCM1794A but I have no experience with digital. I have plenty of these IC to offer if someone can help get me started.
"If you don't like funerals don't kick sand in ninja's face."
Old 29th November 2008, 01:41 AM   #14
Telstar is offline Telstar  Italy
Default DIR9001 vs WM8804
Anybody has compared DIR9001 vs WM8804 in the same dac?
The response of the inner ear extends to at least 200khz - Dr W. Tempest
decent speakers for fist chipamp project morehead21 Chip Amps 3 29th July 2009 05:14 PM
New digital XO project borges Multi-Way 2 8th January 2008 07:49 PM
FINISHED - Pics os my fist Line Array Xmax BR Multi-Way 4 23rd June 2005 09:10 PM
PCM1792A vs. PCM1792 + influence of oversampling on THD etc. capslock Digital Source 2 31st March 2004 07:37 AM
Page generated in 0.09083 seconds (75.93% PHP - 24.07% MySQL) with 10 queries
