| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#81 |
In less the 1000 qty?
#82 | |
Lets hope for an affirmative on that one.
Less pulp more juice Twisted Pear Audio. |
#83 |
Very true.
#84 |
got reply from Bryan.
2 Channel Eval board - $350 ES9008 chip - $47.90 each min order 5pcs. |
#85 |
Yikes even more then was mentioned before. And 5 pieces...better but still a lot.
#86 |
Done deal, getting 5.
Hopefully the prices drop. Cheers! Russ
#87 |
diyAudio Editor
Can't wait for a report Russ...
#88 |
Dustin, I am trying to download the datasheet again. Did you know that the link to the ES9008 datasheet does not work any more?
I need to double check my PCB. Help! ![]() Thanks! Russ
#89 | |
I don't have the 8 channel demo board. It has 8 op-amp sections and connectors for all 8 channels. Each of the 8 channels is differential with a + and - output pin from the Sabre 8. The stereo board I have is configured to sum 4 channels for each of the left and right. I have the stereo I2S signal input on all 4 inputs. Since the channels are differential, the 4 + outputs for each channel are summed as are the 4 - outputs for each channel. Those drive the + and - inputs to the transformer primary for that channel. If you do a search I'm sure you will find many articles on the benefits on summing the outputs of multiple DACs. You probably shouldn't try using transformers if you are doing an 8 channel version. The output impedance of an individual channel isn't low enough. The cost would be very high. ![]() Current mode with an op-amp configured for I-V conversion would be ideal for 8 channel mode. 8-channel voltage mode with the op-amp configured as a diff amp would save some parts cost in the output stage. |
#90 |
Ok, what gives?
For a month or more the datasheet has been publicly available here: http://www.esstech.com/techsupp/ES9008_DataSheet.pdf and even publicly linked to in articles like this: http://www.eeproductcenter.com/analo...leID=205601188 But now, when I can actually buy the chip, I can't get the blimey datasheet from ESS without an NDA or something? HEY ESS!!! ITS ALREADY DISCLOSED!!!! I would be grateful if someone could please email me a copy. Cheers! Russ
| Page generated in 0.13470 seconds (74.26% PHP - 25.74% MySQL) with 11 queries |
