ESS Sabre Reference DAC (8-channel)
Old 30th April 2008, 08:29 AM   #631
peufeu is offline peufeu  France
That thing is a bitch to layout only on 2 layers, lol.
Old 30th April 2008, 11:37 AM   #632
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
Old 30th April 2008, 12:30 PM   #633
Russ White is online now Russ White  United States
Russ White's Avatar
Originally posted by MrMajestic
Great posts Russ, just what I was looking for I think i remember reading somehwre in the thread that you tried DVD-Audio out as well. Where did you tap that?
Edit:
Would pin 46,47 and 50 get me PCM output and could I run that to TP SPDIF module?
Hello,
I have not tested PCM to SPDIF on this player yet, but it looks like you will want to take the PCM signal from:
PLRCK (51) - Left/Right clock
PBCK (50) - Bit Clock
PDATA1 (46) - PCM DATA for channels 1 and 2 (Usually front left and right).
I am not sure the format yet, I will let you know when I try it.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 30th April 2008, 12:43 PM   #634
I mean that a proper layout of this chip needs a plane for GND, a plane for the analog VCC, and a plane for the core voltage, because of the way the power pins are placed, which is slightly too much for 2 layers, you'd need 4 layers.
However 2 layers will work, you probably won't get the ludicrously high crosstalk performance figures in the datasheet, but you'll probably still get high performance, and as long as it sounds good...
I'm not blaming Dustin 'cause the way the power pins are placed around the chip really makes sense, I stand in awe just looking at the pinout thinking "damn, someone finally got it right". So, congrats.
Now, Dustin, can you please add a differential clock input ? There are NC pins there, use them, I mean all the high-perf instrumentation DACs have differential clock inputs (for good reason), PLEASE be the first to introduce this for audio, I'll build you a shrine, I'll immolate chickens in the name of ya, I'll drive to your place with a pack o'beer, but please, give me that differential clock input which is basically the only way to achieve ultra low jitter without massive design headaches.
Old 30th April 2008, 01:15 PM   #635
rossl is offline rossl  United States
rossl's Avatar
the demo board is 2 layers, and it sounds good.
so, I'm sure if you layout a 4 layer board, it will be much better
Old 30th April 2008, 01:18 PM   #636
Russ White's Avatar
I did not have any issues routing the board 2 layer, and I think the routing is very good. if anything it forced me to carefully think about the GND and power returns. We will see how it measures. Personally I don't see the need for a 4 layer board in the least.
Cheers!
Russ
Audio
Old 30th April 2008, 03:12 PM   #637
wildmonkeysects is offline wildmonkeysects
wildmonkeysects's Avatar
You owe me a new keyboard and I second the emotion: although Dustin had mentioned that there are no analog bias lines inside the chip; an LVDS or PECL diff clock input would be XLNT, and that small amount of (internal to the chip) analog circuitry could be done without breaking the design integrity. Rev C? The chip is already good, that would be gooder. That and adding a mono input mode. And disabling automute so that a standalone HW mode would be practical.
Paging Dustin...?
Old 30th April 2008, 03:29 PM   #638
MrMajestic's Avatar
Originally posted by Russ White
Hello,
Cheers!
Russ
Ah yes, pin 47 is not correct, must have been tired Would be great if this worked.
Old 30th April 2008, 03:36 PM   #639
Paging Dustin...?
Haha.
Actually Xilinx gets ridiculously low jitter (useful for über-gigabit speeds) in their humongously expensive Virtex-5 by putting differential clock lines ON THE DIE.
Old 30th April 2008, 04:31 PM   #640
dusfor99 is offline dusfor99  Canada
Hi Peufeu,
The Xtalk number we post in the datasheet are derived from a 2 layer board. To my knowledge there has been no 4 layer board for this chip yet. I just wanted to point that out.
Dustin
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
