Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th April 2008, 02:39 AM   #621
Russ White's Avatar
Send a message via Yahoo to Russ White
It's not uncommon for a manufacturer to protect early data sheets like this. Not so much because they are secret, but more because they are not finished. What I found strange was that the data sheet was available on their site for quite a while, then disappeared.
Less pulp more juice Twisted Pear Audio.
Old 29th April 2008, 05:50 AM   #622
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Any spec on performance is already out there anyway, on their own website, downloadable in excel It probably sais more than the datasheet...
They also provide a free schematic of the ESS website. You could even copy that and have a DAC without the need of a datasheet if you wanted.
A few days ago, this link somewhere on this thread did actually still work, so I'm guessing it still does. If ESS does not want it public I suggest that the link is removed. I'd sign an NDA if I need to.. no problem.
Imho the datasheet does not contain any shocking information that should be hidden from the public, so I guess that Russ is right in saying that it's not public because it's preliminary..
Old 29th April 2008, 07:23 AM   #623
Hi Dustin,
Where can I find some info on the ESS Sabre Ultra 48pin chip?.
From what I have seen of limited info it appears to be nearly indentical to the ESS Sabre Reference 64pin chip,
but with lower channel count?
Raymond
Old 29th April 2008, 09:21 AM   #624
rossl is offline rossl  United States
rossl's Avatar
there are several errors on the datasheet. particulary where it lists what the register defaults should be. register 14 and 15 tell the wrong defaults.
Old 29th April 2008, 01:08 PM   #625
NeoY2k is offline NeoY2k  France
To people waiting for my board: it will take a bit more time to complete it.
Why?
Just because I have to fix my *&#$ computer.
The new hard drive was in my mailbox this morning, I'm trying to rescue all my data :'(
I'll now stop polluting this thread - but be sure that I'm working on it.
When the projet will be ready - just to check again everything, I'll post a new thread.
Thanks,
Nicolas
Old 29th April 2008, 01:09 PM   #626
Well, good luck! And make sure to post a link to the new topic here!
Old 29th April 2008, 09:59 PM   #627
Russ White's Avatar
Default Denon DVD-1920 DSD MOD
OK for those of you who don't mind risking a Denon DVD-1920 and want to get DSD out of it...
Here is how I am doing it:
There are three vias at DBK,DSD1,DSD2. Solder a tiny wire into each via.
I am not sure how I will run these to the panel, but for now just to test the DAC I just used allegator clip jumpers to wires which are installed in the DAC.
It actually sounds very good despite the makeshift wiring! It is definitely much better than the stock DAC, but that would not actually take much.
The DVD-1920 is much easier to modify than the DVD2910, so I would go that route personally.
Cheers!
Russ
Here is a picture of the wires soldered into the whiskers.
Old 29th April 2008, 10:02 PM   #628
Russ White's Avatar
Here is the rig in use. Keep in mind this is not by any means a finished project. I just wanted to show that it works.
Old 29th April 2008, 10:46 PM   #629
Russ White's Avatar
Interesting side note...
If you take out the useless little analog section at back left corner of the player there is more than enough room for a Buffalo/IVY stack and two power supplies and a couple toroidal trafos. Sweeeet.
Old 30th April 2008, 08:09 AM   #630
MrMajestic's Avatar
Great posts Russ, just what I was looking for I think i remember reading somehwre in the thread that you tried DVD-Audio out as well. Where did you tap that?
Edit:
Would pin 46,47 and 50 get me PCM output and could I run that to TP SPDIF module?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
