Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th March 2008, 03:36 PM   #351
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally posted by rossl
Most of the inexpensive transformers do color the sound. Good sounding transformers cost a lot.
The demo board as I have it now is very transparent.
I am not talking about the cheap ones, nobody would even consider using those. I am sure what you have sounds fine, but I would not want to add the distortion and loss of linearity you get with even the best transformers.
I have worked with a lot of pro gear (I am in Nashville, and a lot of my buddies are studio engineers and artists) , and hifi stuff too. Transformers are used a lot, but not really (usually) because they sound "better", more because they allow you get around technical issues. In that role they excel.
Adding a transformer always increases distortion, and it wil do some nasty things to linear performance(to some degree depending on quality) at the top and bottom. The price is irrelevant. It may simply lessen the degree of bad effects, but its still there.
By all means, if you like transformers on the output use them, but I really don't think they are the all around "best" solution all the time. I don't mean to discourage you.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 30th March 2008, 03:56 PM   #352
rossl is offline rossl  United States
rossl's Avatar
Yes, the technical issue is unwanted ground current in the wires.
I have the Behringer digital eq before the DAC. I measure the room with a microphone. Digital eq corrects for room standing waves and non-linearities in the equipment and speakers.
These are measures that most normal people wouldn't take.
Old 30th March 2008, 04:09 PM   #353
flshzug is offline flshzug  Antarctica
Banned
by what means you correct for standing waves? High pass filter ?
its real bad i get these topic notifiers , even though rossl is ignored ...
Old 30th March 2008, 04:13 PM   #354
Russ White's Avatar
There are much better ways to insure there are no unwanted ground currents than to resort to a transformer. Eliminate them by design.
Now if you are stuck with them, then you may not have a choice. In which case you can easily add them.
My opinion is If that if you must use transformers then you must, but if you don't need to, then for the sake of best performance don't.
Cheers!
Russ
Old 30th March 2008, 04:20 PM   #355
Cheers!
Russ
I agree, transformers are OK for power supplies.
André
Old 30th March 2008, 04:36 PM   #356
The ESS output stage using AD797s is actually very good, but so is my transformer stage. Also, I've tested with and without the transformer, and can say that it's pretty transparent, but really the differences between the various approaches are very small in comparison to other stuff that can be done.
The AD797s are -120dB THD, far more linear than any transformer - but that doesn't translate to any audible advantage.
Old 30th March 2008, 04:58 PM   #357
rossl's Avatar
The audible advantage, that is the key.
The typical speakers and listening room are far more non-linear than any of our schemes for coupling that we have discussed.
There are differences in distortions. I do not find the distortion from a good transformer objectionable. Some people want to hear the distortion from tubes. I find that some op-amp circuits sound objectionable even though they may be linear.
I doubt if we all are ever going to agree, but the passive output I am listening to now sounds very good to me.
Old 30th March 2008, 05:13 PM   #358
Cappy is offline Cappy  United States
Ross,
I agree. One man's neutral is another man's colored.
I seem to be particularly sensitive to transistor colorations. I've been in situations where other people call a component neutral and I hear bleached sound missing correct harmonics and a mechanical treble.
Also, the brain is good at filtering out distortion. If people have been listening to transistors for many years, for them the sound may indeed be neutral. There are probably many neuron pathways that were set up in the brain over time to handle it, even! Same goes for me filtering out tube distortion.
Old 30th March 2008, 05:26 PM   #359
jcx is offline jcx  United States
at least read the transformer line driver section of Walt's book:
http://waltjung.org/PDFs/ADI_2002_Se..._Drivers_I.pdf
6.69+, p27+
Old 30th March 2008, 08:27 PM   #360
Send a message via ICQ to fierce_freak Send a message via AIM to fierce_freak Send a message via MSN to fierce_freak Send a message via Yahoo to fierce_freak
I have a circuit which both sounds and measures very neutral and incredibly low THD (measured), and it takes advantage of the very high DNR of the chip. GND loops have not been an issue at all, and the balanced (symmetrical) nature of the circuit rejects common mode noise very nicely.
Does this mean you've had a chance to get one of your boards up and running, or is this in reference to a past circuit?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
