ESS Sabre Reference DAC (8-channel) - Page 26 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th March 2008, 01:50 PM   #251
Sheriff is offline Sheriff  United Kingdom
Sheriff's Avatar
Send a message via Skype™ to Sheriff
Blimey, you have me at a disadvantage.....! :-)
Old 4th March 2008, 04:52 PM   #252
That explains the worried monkey face then
Old 4th March 2008, 05:57 PM   #253
Default Re: I2S Data width
Originally posted by FuriousD
Hi Dustin,
Am I correct in assuming that the 352kHz I2S input has data width of 24Bits? In which case i have to restrict my filtering to a 24-Bit data width which is not good. The advantage of the Texas part is that when you bypass the filter you have access to a 32-bit data width (Admittedly only at 192kHz but I can live with that).
I have a good idea what you have done after this, but the filter is the key to going from good sound to great sound. When I designed the concept of the Chord DAC64 filter it took a fairly unremarkable D2A concept and made it sound excellent.
I would love to be able to take an improved variant of that concept and couple it with the excellent performance of your modulator and DAC, but 24-bits is just not going to cut it.
If your filter has several stages, can we break in further down the line? at a wider bit width or faster rate?
Is there a work around on this? and if so what sort of time frame would this based upon.
Throw 32 bits at it then, it will be fine, the 8LSB's will simply be ignored.
Old 4th March 2008, 06:01 PM   #254
The ESS DAC itself uses a user selectable bit width quantiser. Normally set around 6-Bits. This is the actual DAC resolution. So Delta Sigma modulation is being used to sacrifice out of band noise perfromance in favour of increasing in band SNR.
If you read the datasheet for the ESS part you will see that it has an internal data path of 48-Bits. You will note that the DAC64 has an internal data path of 64-Bits. There is a good reason for this.
Whilst 24-input bits gives a theoretical DNR of 144dB, if the data path has out of band components at -144dB prior to the actual DAC stage internally, then the massive out of band gain of the modulator will amplify these components up to a level that is very much significant.
24-Bit input data x 24 bit tap coefficients in the filter = 48-Bit result. To input that back into a 24-bit input, you would need to dither or just truncate it back down to 24-Bits and that is where the problems begin.
This is how the datapath is in the Sabre DAC.
24 bits in, 24 bits coeff, 56bit MAC, 28 bits to the modulator, beyond that there was no measurable difference.
Dustin
Old 4th March 2008, 06:04 PM   #255
Default Re: Re: Re: Re: I2S Data width
Originally posted by InfiniteGain
I started this thread. I believe the topic is specifically based around my initial question of how us DIYers get our hands on one or two chips in low volume, and if anybody had already used it and could give feedback on how it sounds given the impressive specs.
Those questions remains unanswered. It seems the chip is really still a prototype and is yet to undergo a few revisions. There has only been technical questions and answers about certain aspects of the chips design implementation and some interfacing options. They only come in handy if I can get hold of it to do something with it.
Isn't there chip aviable from Brian at Shaw? I talked to him myself and he said he has some for people.
Old 4th March 2008, 07:19 PM   #256
The DAC64's filter is a Watts Transient Aligned filter (WTA Filter). Are you Rob Watts?
So who are you then? Clearly you know alot about Chord, but no quite enough. I admit that I don't know Mike Dixon (after my time), was he responsible for the SMPS that gave the first DAC64's >4nS of jitter? (See Sterephile for details) and yes I'm sure that Rob would love the world to believe that he was responsible for the filter design in the DAC64. He has made a good living out of Zetex off the back of that myth. Implementation and design are two very different things. I don't think that I can add anything more than that without being knuckle wrapped.
I still have the original Matlab files for the filter design, which when I left was a 2/8 channel surround sound processor implemented in FPGA based on 3x Spartan II's (Stop me when you recognise the sound of any of this). The 8 Channel version was simply a restricted version of the original 2-channel design which used the full resource of the 3x devices. Left Filter, Right Filter and DAC Modulator in the third.
The filter was what set the DAC alight and has one fundamental concept that differs from what Texas, AKM, Analog and from the datasheet shown what ESS do as well.
(Sorry I know that this is meant to be a glory be to ESS thread, but I am still interested in doing a super DAC as a project and would be happy to share designs, schematics & results with anyone who is interested. I fully agree that if you want to participate on this forum then you need to contribute not just use others to further your own designs.).
DAC's are all about 4 main areas. Clock, PSU, Modulator & Filter. It looks on paper like the Modulator section is about as good as it gets, the clock as suggested above can improve the demoboard sound, so that backs that one up. I will shortly be investing in some very low phase noise VCXO's if anyone is interested in group purchase then let me know.
That just leaves the PSU and the filter. The Clock and DAC PSU's are about as vital as they get, and I can get better CD sound from a crystal simple CS4390 that i've ever managed elsewhere simply by attending to the PSU on the clock and the DAC. The next step would be implement this onto something capable of much more.
By Dustin's flippant remark about discarding 8-bits clearly i've annoyed him by suggesting that design could be improved by the filter. I hope that he does include a filter bypass on future revisions as per the wolfson or the texas, as I would love to see how far CD performance can be taken with his excellent technology.
Old 4th March 2008, 07:28 PM   #257
Dustin
That would be my point...
28 Bit's to the modulator? So not 24 then?
i.e. worth having the extra 4-bits at least
Old 4th March 2008, 09:34 PM   #258
Hi FuriousD,
Its wan't intended to come across this way.
I agree with what your say about needing more then 24bits to drive into the modulator, this is exactly why I nuged it up to 28bits. I went as far as 36bits in prototypes, but then opted to drop to 28 since in my design that is where the digital noise floor dropped out of site. Future rev will have something like this.
That being said thre are still some filtering going on at the 28 bit level before the signal hits the noise shaper, or even the jitter blocker for that matter.
Dustin
Old 4th March 2008, 11:47 PM   #259
Send a message via ICQ to fierce_freak Send a message via AIM to fierce_freak Send a message via MSN to fierce_freak Send a message via Yahoo to fierce_freak
Awesome stuff. I look forward to Russ W.'s implementation of the Saber DAC.
Old 5th March 2008, 02:14 AM   #260
Account Disabled
Is there anybody on this thread other than myself who does not work for a commercial electronics/audio firm and/or have an electronics degree or doctorate?
For the moment, I don't fall into those categories either LOL
Any rough idea of when we can expect such a version? Come on, don't tease us so... When I asked you about three weeks ago, you said it's not cost effective to do another mask until there's sufficient demand for this feature, but I nope by now enough others have shown interest.
By the way, I'm still hoping for an answer to my question to FuriousD:
Originally posted by abzug
So what's wrong with dithering? If whatever error is out of band, why would it be a problem, regardless how much amplified?
Copyright 1999-2017 diyAudio
