ESS Sabre Reference DAC (8-channel)
Old 28th June 2013, 03:22 PM   #2261
Bunpei is offline Bunpei  Japan
Hi, Simonvan!
What is your definition of PCM?
A possible answer may depend on the definition.
Beside that, do you have a clear understanding on a delta-sigma( sigma-delta) modulation?
Bunpei
Old 30th June 2013, 09:37 AM   #2262
I'd like to show my own understanding here.
ES9018 incorporates a multi-level (65 levels) delta-sigma(sigma-delta) modulator.
In "White Paper" published by ESS, they use the term "six bit". However, I think it should not be interpreted as "PCM" because "PCM" does not refer delta-sigma modulated data and refers a binary format of 2's compliment in general. A DA module in ES9018 processes 65 level delta-sigma modulated data coded in "Unary" or "Thermometer" coded and DEMed.
In the case of PCM input, a usual PCM data is converted into 65 level delta-sigma modulated data.
In the case of DSD input, I imagine the original DSD data is also converted first into a certain form of internal multi-level representation and then the data is delta-sigma modulated into 65 levels as PCM is processed.
Old 14th July 2013, 02:17 AM   #2263
syskwl is offline syskwl
Default Pls tell me about 2 register setting for stereo mode for SPDIF/SERIAL/DSD input.
To make to get stereo mode for SPDIF/SERIAL/DSD input, which 2 registers do I set. I guess 1 register is #14. If it is right, another?
Originally Posted by dusfor99 View Post
Russ,
I will put together a sorta mini app note on how to wire the chip up such that you only need 3 pins connect and you can get all channel to parallel together in all 3 modes. I know I should have just made it easy programming but that would be no fun right? No just kidding, I really overlooked that and its my mistake. But for now, you can short
DSD5 to DSD1
DSD6 to DSD4 to DSD2.
With these pins connected like so, there is 2 register setting you can make to get stereo mode for SPDIF/SERIAL/DSD input.
Also, pin25 on your schematic should be connected to 3.3V
I will get you the register settings soon.
Dustin
Old 14th July 2013, 02:30 AM   #2264
Please tell me about the IC4(6 pin smd), IC5's name on the Buffalo 3 SE input.
Old 28th July 2013, 09:54 AM   #2265
Default Analog output without AVCC power
I'm recently trying a various AVCC power supply systems for ES9018 of mono configuration.
In the process, I happened to forget to connect an AVCC power and turned digital 3.3V and 1.2V on! Alas, how so? A small sound came from my amplifier though the level is low. What internal mechanisms may make such phenomena?
In my configuration, 8 channel analog signal pins are tied and connected to a primary of line transformer. No voltage is given to those analog out pins at all.
Old 29th July 2013, 04:47 PM   #2266
qusp is offline qusp  Australia
qusp's Avatar
maybe it worked in some kind of Class B way? where the signal itself supplied the analogue bias voltage enough to get some signal through?
Old 30th July 2013, 02:15 PM   #2267
Hi, qusp!
Thank you very much for your post. I'm sorry that I could not catch on your explanation as I can imagine no circuit diagram along with your explanation because of my limited knowledge.
You told a possible "N-channel (MOS) arrangement" in the analog output stage of the DAC. Does your guess of this time match well your previous speculation?
Bunpei
Old 30th July 2013, 03:52 PM   #2268
qusp's Avatar
i'm just guessing, but then thats all we can do yes?
what I mean is, depending on the exact format or type of the fets (unknown), perhaps the missing analogue reference supply can be replaced by signal, so the swing of the signal itself (generated previous to the output stage) is enough to get something through, by turning the fets on with whatever signal voltage is over the gate threshold voltage and RDSon, but not with enough drive/bias to get full output. without AVCC the return will be compromised too, which would also contribute to the lack of output strength, but I can see how there could be something.
again i'm just guessing here but that is a mechanism that would allow it. distortion will be significantly higher and the waveforms incomplete, but it would be recognisable as music.
Old 1st August 2013, 03:09 PM   #2269
Default DPLL is not likely to be disabled on ES9018-2M
When I read a press release of new ES9018-2M, I got such an impression that we could disable DPLL functionality on the chip by setting a new register appropriately.
Today, after I browsed its datasheet for the first time, I thought it would be impossible.
Does anyone interpret the datasheet descriptions in different manners?
Old 14th January 2014, 12:59 PM   #2270
coolnose is offline coolnose  Europe
coolnose's Avatar
Default High pitch whining sound from ESS9018/TPAIII
Hi All,
I encounter some issues with the following setup:
MiniDSP Mini-Sharc with the digital input module (MiniDIGI) ->
TPA Buffalo III in voltage out mode (loaded with a 1K resistor and a 3300pF Low-pass filter)
I get a high pitching noise on the oputput of the DAC, that is with or without the I2S lines from the Mini-Sharc connected or not With the I2S lines connected the noise is changing slightly and less stable though.
All DIP-switches are OFF (apparently new firmware) as per the datasheet recommandation, only the SP/DIF input is ON (i.e. set to bypass).
I have tried different supplies for the DAC board (simple 7508 regulator, LT1963 regulator) nothing wont change.
I'd nned some help troubleshooting the thing, I am slowly getting crazy...
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
