ESS Sabre Reference DAC (8-channel)
Old 7th April 2013, 01:40 PM   #2191
AAK is offline AAK  United States
Hi roender,
The BIII DAC does accept "No Bandwidth". It's the DPLL BW Default switch setting.
Best regards,
Al
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 7th April 2013, 01:43 PM   #2192
Shinja is offline Shinja  Japan
it is whird. Why does tackbon not generate BCLK via dividing MCLK?
Can it call "sync MCLK"?
Old 7th April 2013, 01:46 PM   #2193
roender is offline roender  Romania
roender's Avatar
Originally Posted by AAK View Post
Hi roender,
Best regards,
Al
In that case, I have to proudly declare that my setup is unlock free. Not a single unlock from power on till the end after almost one hour of listening.
Old 7th April 2013, 01:59 PM   #2194
AndriyOL is offline AndriyOL  Ukraine
Nice work as always roender. Could you describe your tridents, avcc modifications and power supply solution?
If for pristine and pure adoration - it's diyAudio dedication!
Old 7th April 2013, 02:04 PM   #2195
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Originally Posted by roender View Post
The level shifters didn't required an independent voltage source, other than the power supply for the core.
My assumption is that it was much simpler to access the shifter supply on the chip by external connection rather than internal.
That is my understanding from ESS.
Old 7th April 2013, 02:09 PM   #2196
roender, nice job. Really like your setup. Just curious, can you try an spdif input with the DPLL set to "No Bandwidth" and DPLL Multiplier set to 1X to see if your setup still maintains lock? Thanks!
Al
Old 7th April 2013, 02:19 PM   #2197
roender's Avatar
Al
I just powered on the DVD player and voila, no unlocks!
The DAC switches automatically from I2S to SPDIF when it sees signal on D3 which is connected via TOSLINK
Old 7th April 2013, 02:33 PM   #2198
Hi Brian,
Just to clarify. In Buffalo III, when setting the DPLL BW to Default is the "No Bandwidth" selection in Register 11 being used, and Register 25 set to "Allow all settings", or is Register 25 set to "Use the best DPLL bandwidth settings". Thanks!
Al
Old 7th April 2013, 03:52 PM   #2199
roender, I think I misspoke. After looking at the ES9018 DS, and the Buffalo III manual in more detail, I don't think Buffalo III allows for the "No Bandwidth" setting. I think the "Default" dip switch selection sets Register 25 in the ES9018 to "Use the best DPLL bandwidth settings" which is the initial default setting.
Al
Old 7th April 2013, 07:12 PM   #2200
roender's Avatar
Al
You are right, BIII doesn't support DPLL "No Bandwidth" setting.
What confuse me is why DPLL is up and running in sync mode?
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
