| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#2031 | |
is choosing a less facetious title...
without going to google, can you explain by what mechanism adding too much decoupling might cause harm and what steps you have undertaken to avoid it? just so we know you have considered the risks; even if you havent objectively tested ANY of them. people have had their dacs start to malfunction from overclocking on your recommendation, yet you still deny that there is any problem. You cannot even supply a theory by which it would provide an advantage to do it, forget measurements, I know you have an aversion to them, but you cannot even theorize, here in Bunpei we have someone far more knowledgeable than you with more experience doing more advanced modifications on ESS dacs than you and with something of a reputation for doing so. He is going on record telling you that he has damaged chips this way, then you answer that with the above? the truth is you have no idea what is going on inside the chip, if you did you would see overclocking is futile, you feel it with your finger, its not burning, so is OK? your finger temperature test does not hold much water.... lets list it out overclocking lowers temperature of a fully operational es9018 dac chip? no, it raises the temperature of a fully operational es9018 dac chip overclocking has lower noise? no, overclocking causes more noise overclocking helps maintain better lock? no, it makes it more difficult overclocking produces cleaner audio? no, it creates more glitches, more noise, more RFI overclocking puts less load on the power supply and decoupling? no, it puts a higher load on all of these things overclocking allows higher sample-rates? no, there is no material released that the ESS can play with higher than recommended speed clocks that it cannot play without them. overclocking has lower jitter and allows the use of lower jitter clocks? no, the clocks you are using are lower quality than the standard rate chrystek, NDK etc parts. overclocking makes it easier to maintain proper digital and analogue signal integrity? No, it makes it harder then we have all the issues of regulators, AC and Z termination, PCB designs etc being designed for different speeds etc etc. To top this off, you also recommend running the AVCC voltage at up to 4VDC. I run 3.65VDC but I would not run 4v personally, let alone recommend it to others while also overclocking so what is it, what is the benefit to offset the obvious risks? there must be one? yet you paint me as the negative one, i'm just trying to offer a voice of reason when you dont seem to care what happens to other peoples equipment. I ask for a reason to take these risks, you cannot provide one. I'm the negative one because it causes you frustration. DIYAUDIO is a technical forum where we discuss various techniques to improve our audio equipment, both subjectively and objectively. if you are going to make claims, you should expect now and again to be asked to back them up. If you dont like that, there are plenty of other forums where such claims are accepted without question. Last edited by qusp; 23rd January 2013 at 07:54 AM. |
#2032 |
Great post! You have stile, I can say...
One may test first the regulators if they work well with large capacities on its outputs, before coupling it to the DAC chip... It is a basic precaution... As usually all the regulators have over current protection. I can not see that in one of my posts I claim that ESS9018 have to have 4v on AVCC. I use 3,6v. Else your last post is full of exaggerations. Specially when you claim that I destroy the folks DACs... Sorry, this it may be only stupid. By the way, it is enough surprising for me that Bunpei with his experience have destroyed so many chips. But it may happen on some unlucky days... |
#2033 |
its spelled style... it wasnt meant to be stylish, it was meant to be clear, since you seem to have such trouble understanding the very basic intent of my query. Yet you continue to avoid the questions.
There was not a single exaggeration, rather matter of fact actually, please stop it with playing the victim. There is nothing like the exaggeration where you claim that I said you destroy peoples dac chips, I said peoples dacs have (very predictably) started to malfunction on your recommendation to run higher clock speeds. that is a fact, not an exaggeration. it is also a fact that you say its OK to run at 4v and try to back it up with Dustin Saying its OK, it is true the pins are 4v tolerant, but not at over 100MHz and you would want to be very sure that the regulator you use does not have higher start up voltage and its voltage reference doesnt vary with temperature, resulting in higher than 4v. running the higher voltage at the same time as overclocking will only increase the likelihood of permanent damage. |
#2034 |
You just do not want to accept, or do not understand that simple fact that this my "damaging" setup it is working very well and stable for months now, with an exceptional sound?
I see that you want to force in your "logic", based on your own fantasy about those 4v AVCC. I`ve wrote already many times that I do not have 4v on that pins, but 3,6v. Sorry, but I will not continue to answer your posts from now on. I have got enough of your such interventions... I repeat here once again for the other readers about my functional (in use) hardware setup for ESS9018: 125Mhz clock, connection 2-3mm between oscillator (SAW type now) out and DAC chip clock in. Oscillator powered directly from battery. Ultra low noise regulators for AVCC - 3,6v, 6-7mm long connection to the DAC, with 1200µf decoupling ceramics caps on this rails, and soldered directly to the chip pins. Same type caps 500µF decoupling on all digital power rails. DAC chip completely shielded, oscillator outside. Silver wire for all connections. As my time will permit, I think to come back with some figures in the near future... Last edited by Coris; 23rd January 2013 at 08:01 PM. |
#2035 |
you have reading comprehension issues...
among others.... you stated yours didnt work at 133MHz, so you 'eased back' to 125MHz and 'the problems stopped' KlipschKids stopped working at 125MHz. but nooo, nothing wrong with the faster clocks, faster must = better.... it just must... because it just does Last edited by qusp; 23rd January 2013 at 11:12 PM. |
#2036 |
Does anyone knows where the 100 MHz number comes from?
The only number in the data sheet is: 1.536 MHz is highest incoming sample rate according to spec (bypassing the OS filters). x64 results in 98.304 MHz
www.hifiduino.wordpress.com |
#2037 | ||
Under Construction:Ian's i2s FIFO wiki |
#2038 |
Oh yes, I remember seeing that. :-)
#2039 |
#2040 | |
(I hope you are still a read-only member on this thread and you read this post.) I do not intend to blame you because the overvoltage experiment was not inspired by you. I made my risk-taking decision before the experiment and I did not accuse anyone else. I could souce the DAC chips for replacement easily. However, many DIY users in this world may have their own situations. Some of them will blame you keenly when they encounter severe problems in case of making modifications base on your claim. Anyway, I could experience a significant influence of quality of AVCC power supply including a choice of types and values for decoupling capacitors through the series of trials. Bunpei |
