| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1871 |
Hi, PHEONIX,
Please read my PM sent to you. Bunpei |
#1872 |
Does anyone try any synchronous configuration of I2S for ES9018, with such lower MCLK frequency range as 11. 2896 MHz, or 22.5792 MHz for fs=44.1 kHz source?
I just tried 22.5792 MHz synchronous MCLK input to master clock XI pin of ES9018 and found it feasible enough for from fs=44.1 kHz to fs=352.8 kHz sources under OSF = OFF conditions. |
#1873 |
Hi, Bunpei
I' ve just tried feeding 11.2896mhz to BuffaloII directly from QA-550's XO pin after reading your post. It works very well ![]() I found it gives better soundstage and 3D imaging. Quite enjoyable although it can play only 16bit/44.1khz wav files. |
#1874 |
According to the ES9018's datasheet, IF you only play 16bit/44.1khz files, 11.2896mhz is enough for
OSF mode. I had tried it after previous post and the result was much better than bypassing OSF. Now Mid and Hi are much cleaner and more opened, and more "natural" in addition to detailed/better difined sound Last edited by wktk_smile; 4th July 2011 at 09:36 AM. Reason: hope to avoid misunderstanding |
#1875 |
Hi, wktk_smile,
Thank you very much for your replies to my question! Yes, you are correct. As far as a master clock frequency > 192 fs, OSF mode can be ON. Have you already tried, 90.3168 MHz(44.1 kHz x 2048) or 98.3040 MHz(48 kHz x 2048) synchronous master clock of SDTrans384 with your Buffalo II? Bunpei |
#1876 |
Yep, I received EEPROM for synchronous ES9018 from Chiaki san.
It's really astonishing. I will report to "MicroSD memory card Transport Project" thread. |
#1877 |
Close-up photos are shown on the site;
Wizard High-End Audio Blog: More pictures of Accuphase DC-901 Two ES9018 chips per channel, 16 DAC modules for one channel! ![]() ![]() One 40MHz master clock oscillator per channel. |
#1878 | |
Best |
#1879 |
Good news to those who wanted to see the ES9018 DAC datasheet!
I spoke with Bryan at Shaw Electronics (shawelectronics.com), the US distributor for the chip... he said that 6 months ago the ES9018 datasheet was taken off the non-disclosure agreement list, so now you just have to request it and he will send it to you. So, if you want the ES9018 DAC datasheet, kindly email Bryan at "bryan at shawelectronics dot com" and ask!
#1880 |
is choosing a less facetious title...
ermm, this has been public knowledge for quite a while and has been posted in here already, thanks though =)
