ESS Sabre Reference DAC (8-channel) - Page 187 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th June 2011, 03:28 PM   #1861
Bunpei is offline Bunpei  Japan
Originally Posted by Russ White View Post
... I have been able to do the same via XMOS for quite a while now. ... I have also experimented with generating the bit clock and word clock by dividing the master clock. Which worked well, but requires two master clocks.
Oh, you have already achieved a stable play of 384 kHz/32 bit sources with OSF=ON, Jitter Reduction=ON, DPLL BW ="the lowest" on your Buffalo II/80 MHz/100 MHz. It's great!
Is the XMOS-based USB interface capable of seamless play of 44.1 kHz to 384 kHz without changing its wiring or configuration?
Anyway, I've been actually waiting for your X-MOS product for more than one year without buying other similar kits.
I really hope your superior product is realized immediately and many people can reproduce the sound you already have and enjoy it.
By the way, Chiaki's approach is one master clock for one sampling frequency series approach.
Old 28th June 2011, 03:37 PM   #1862
Russ White's Avatar
Send a message via Yahoo to Russ White
So you mean he is only using 48khz multiples?
Less pulp more juice Twisted Pear Audio.
Old 28th June 2011, 06:07 PM   #1863
One oscillator is employed for 44.1 kHz series and another for 48 kHz series.
Totally two oscillators. Nothing more. Is it the same configuration to yours?
Old 28th June 2011, 06:10 PM   #1864
Russ White's Avatar
Yes. Then using the selected clock to generate the clocks for PCM.
In this case you would not use the 80 or 100Mhz clocks on the Buffalo.
The reason this works is because the DPLL is basically doing nothing now, or rather it can't help but be in synch
Old 28th June 2011, 06:23 PM   #1865
... or rather it can't help but be in synch
I think we can call it as a "synchronous mode".
When a transport can send I2S signals of high quality enough , the mode may yield better results.
Old 28th June 2011, 10:46 PM   #1866
PHEONIX is offline PHEONIX  Australia
Hello guys
The Buffalo II board what pic micro is used.
Arthur
Old 28th June 2011, 11:07 PM   #1867
Russ White's Avatar
Its not a PIC, is AVR Atiny type microcontroller.
Old 28th June 2011, 11:19 PM   #1868
BrianDonegan's Avatar
ATTiny85
Old 29th June 2011, 08:29 AM   #1869
Originally Posted by BrianDonegan View Post
ATTiny85
Hello Russ
Does that use an external crystal clock.
May I ask why you left microchip micros.
Arthur
Old 29th June 2011, 02:02 PM   #1870
Hello Bumpie
You mention "Copper foil & Polyphenylene Sulfide(PPS) Film Capacitor" can I ask you what is the brand of this part and are they still available.
Arthur
Copyright 1999-2017 diyAudio
