ESS Sabre Reference DAC (8-channel)
Old 15th May 2011, 12:53 PM   #1851
AndriyOL is offline AndriyOL  Ukraine
Originally Posted by Bunpei View Post
Does anyone succeed in applying "the lowest" DPLL Bandwidth parameter for I2S input with OSF/On, Jitter-eliminator/On?
One of SDTrans192 Rev. 3.0 users, sunacchi in Japan, reported his recent achievement in his blog page (In Japanese).
BaffaloIIにArduinoを付けてみた: Ama Ama Audio Visual
His DACs are dual mono configured Buffalo IIs ( with Fidelix 96MHz oscillator) and controlled by Arduino.
Even for 352.8 kHz/24 plays, he said he succeeded in maintaining locked state for a long period(but not perfect). I think his special enhancements on power supplies of both SDTrans and Buffalo IIs resulted in "the lowest" setting.
What and what for he placed on top of solid caps in amp-cpm4 image?
If for pristine and pure adoration - it's diyAudio dedication!
Old 15th May 2011, 02:32 PM   #1852
sunacchi is offline sunacchi
silicon carbide(GC#16)
GC#16 absorbs an electromagnetic wave (noise) with kind of a granular whetstone to grind of the quality of silicon carbide system, and to change it into heat.
-yahoo translate
Old 4th June 2011, 09:42 AM   #1853
Bunpei is offline Bunpei  Japan
One of SDTrans192 Rev. 3.0 users, sunacchi in Japan, reported his recent achievement in his blog page (In Japanese). ...
... Even for 352.8 kHz/24 plays, he said he succeeded in maintaining locked state for a long period(but not perfect). I think his special enhancements on power supplies of both SDTrans and Buffalo IIs resulted in "the lowest" setting.
sunacchi retracted his previous results and posted his correction.
He had found that his previous results had been collected on OSF/Off mode.
皆さん、申し訳*りませんでした: Ama Ama Audio Visual(In Japanese)
With OSF/On mode his updated achievements are;
ES9018 DAC: Twisted Pear Audio, Buffalo II boards of dual mono mode with Fidelix 96 MHz oscillators
Transport: heavily tweaked Chiaki's SDTrans192 Rev. 3.0 board
PCM 44.1Khz:MEDIUM
PCM 88.2Khz:MEDIUM_H
PCM 96Khz:HIGH
PCM 192Khz:HIGH
PCM 352.8KHz:Use best DPLL Settings
Transport: heavily tweaked ElecrArt's USB Dual Audio board
DSD 2.8M MEDIUM_L
DSD 5.6M MEDIUM
Bunpei's latest results are;
ES9018 DAC: Twisted Pear Audio, Buffalo II single board with NDK 100 MHz, ultra low phase-noise OCXO, 9525D
Transport: "Copper foil & Polyphenylene Sulfide(PPS) Film Capacitor" added SDTrans192 Rev. 3.0 board
PCM 44.1 kHz:THE LOWEST
PCM 48 kHz:LOW
PCM 96 kHz:MEDIUM
PCM 176.4 kHz: HIGH
PCM 192 kHz:HIGH
PCM 352.8 kHz:THE HIGHEST
Old 10th June 2011, 02:09 AM   #1854
glt is offline glt  United States
Bunpei,
Thanks for the post.
This data experimentally confirms the best capabilities of the Sabre32 DAC with respect to DPLL settings.
And this is the end of the DPLL mystery :-)
www.hifiduino.wordpress.com
Old 19th June 2011, 07:01 AM   #1855
I was much pleased with your appreciation. My study wad inspired with your series of valuable and intensive blog articles on the topic of DPLL Bandwidth parameter setting.
I still have two mysteries on the parameter setting.
1. Why DPLL Bandwidth parameter setting value is still effective even if I set;
"Bypass and stop JITTER REDUCTION"
Is the narrow meaning of "JITTER REDUCTION" not the same of "employing DPLL"?
2. What does "Use the best DPLL bandwidth settings" mean?
Some people say "the best DPLL bandwidth settings" is equivalent to a fixed "medium" or "medium-low" setting. If it is so, I guess it is of "Multiply the DPLL BANDWIDTH setting by 128".
Old 19th June 2011, 07:47 AM   #1856
Default DSD mode processing on ES9018
An ES9018-based DAC, CAPRICE by Fidelix is bringing up a mood of reappraisal of DSD sounds in Japan. The DAC offers an option of raw DSD signal input and I heard that at least two famous audio reviewers in Japan purchased CAPRICE with the option.
According to Functional Block Diagram in Product Brief document of ES9018, it seems for me that DSD signals are converted into PCM at the stage prior to oversampling in ES9018. This approach seems quite different from such DAC chips, TI DSD1702 or DSD1608 that has a dedicated DSD filtering signal path.
How do you feel about this point?
Old 22nd June 2011, 12:02 AM   #1857
1- There is some info here: ESS Sabre Reference DAC (8-channel) I think this only works if you provide your own master clock into the chip (replacing the oscillator)
2- Here is my guess: I think "best" means the next level after "highest" based on the fact that there are no hiccups even when the DAC is cold.
Old 22nd June 2011, 03:24 PM   #1858
Thank you very much for your information!
I completely agree with your consideration.
Old 27th June 2011, 04:37 PM   #1859
Chiaki succeeded in playing 384 kHz/32 bit high resolution sources using the combination of his SDTrans384 and ES9018 based DAC with the setting of DPLL bandwidth parameter = "the lowest" and OSF mode="ON" without any unlock events.
In order to achieve this, he redesigned logic circuits in FPGA where I2S signals were generated based on clocks given from external oscillators and PCM data read from SD card. Bunpei reproduced the experiment and obtained a very good sonic improvement.
Who can make a guess on his method?
Old 27th June 2011, 04:55 PM   #1860
Russ White is offline Russ White  United States
Russ White's Avatar
Bumpei,
What do you mean for us to guess at?
This is not surprising. I have been able to do the same via XMOS for quite a while now. I don't know why using FPGA would be any different.
I have also experimented with generating the bit clock and word clock by dividing the master clock. Which worked well, but requires two master clocks.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
