ESS Sabre Reference DAC (8-channel)
Old 2nd February 2011, 08:32 AM   #1791
qusp is offline qusp  Australia
qusp's Avatar
is it a buffalo II? if not you are thanking the wrong guy, brian did not design the sabre chip, only designs that use it
Old 2nd February 2011, 08:34 AM   #1792
qusp's Avatar
Originally Posted by AR2 View Post
I would think that buffering would be advisable and necessary but I do not know what is used for buffering of I2S. Could you please elaborate little bit more in detail what is used for this purpose. I know how to do it for S/PDIF but I do not think that same way could be done for I2S.
Thank you.
what is needed is actually quite similar. LMV7219 would be fine
Old 2nd February 2011, 11:33 AM   #1793
Zoran is offline Zoran  Serbia
It is not buffalo
it is the dac i designed
(original design, not copy at all points...)
Old 2nd February 2011, 11:37 AM   #1794
Sorry i think about Dustin,
but Brian could help if he know how to?
if He is still around at the topic?
sorry again
Old 2nd February 2011, 04:08 PM   #1795
glt is offline glt  United States
Originally Posted by Zoran View Post
I have one Q
(Maybe Brian is most qualified person to answer...)
I have Sabre dac playing (very good)
in factory settings 80MHz MCL, 24bit, i2S, Ioutput, 50KHz/fast roll-off, jitter reduction
and L/R 4 X DAC ballanced out.
My Q is can I set the PIC to SET all DAC units inside to single ended Iout
to one channel?
I want use single chip per channel and I do not need ballanced outs...
And thankk You Brian for the great great DAC chip
You can set all DACs with the same phase if that is what you are asking... Take a look at the datasheet...
www.hifiduino.wordpress.com
Old 2nd February 2011, 06:43 PM   #1796
I went through the sheets,
and i saw the option to switch the phases opposite
BUT
I think that there is no point because
the dac unit (like for the example dac1 to 8
are still ballanced...)
and
turning the phase in mean that You can get only oposite phases
against factory setting...
I simply could not find the information how to split
the + and - Iouts from the single dac unit inside?
Or maybe I get it wrong?
thanks
Old 2nd February 2011, 06:46 PM   #1797
I need to change the phase of one half of the dac unit
this one "-" to change to "+",
and for every dac unit inside the chip (8 pieces...)
I dont need ballanced line.
Old 3rd February 2011, 12:35 PM   #1798
Bunpei is offline Bunpei  Japan
can I employ 90.3168 MHz master clock with Sabre dac?
( 90.3168 MHz = 4 x 22.5794 MHz = 4 x 512 x 44.1 KHz )
As for ES9018, I have tested 80, 96, 100 MHz and my co-worker in Japan tested 92 MHz as well. No problems for all the frequencies as long as you play <= 192 kHz. Only if you play 352.8kHz audio files on OSF mode, it's better to use 96 or 100 MHz.
(To say exactly, 512 x 44.1 kHz = 22.5792 MHz )
Old 4th February 2011, 05:59 AM   #1799
thanks Bunpei
Old 4th February 2011, 04:48 PM   #1800
alexcount is offline alexcount  United States
Send a message via AIM to alexcount Send a message via Yahoo to alexcount ESS Sabre Reference DAC (8-channel)
Thank you Bunpei,
I have the board bunpei mentions, the ElectrArt USB-Dual-Audio, and am now enjoying DSD playback from my PC to the ES9018 Buffalo-II DAC. Both 64fs 2.8Mhz and 128fs 5.6Mhz are supported, both playback and record. I started a thread with more details. Just want the DIY community to know DSD is here.
btw, price was $384 shipped to the US built and tested, including unpopulated DSD1794a DAC and PCM4202 ADC and meter/sample rate led pcb.
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
