ESS Sabre Reference DAC (8-channel)
Old 28th December 2010, 05:18 PM   #1681
Russ White is offline Russ White  United States
Russ White's Avatar
Certainly the Buffallo II makes design choices that will effect what registers you will want to change. But there is nothing onerous about that at all. In fact we made careful decisions after lot of consultation with Dustin and others.
That said if there is demand we may go ahead with a multi channel multi input PCB. It really just depends on if it is useful enough to enough people to make it viable.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 28th December 2010, 05:45 PM   #1682
RayCtech is offline RayCtech
As I wrote in the TPA thread I did a test of the effect of the default mapping of the inputs and the mapping used by the Buffalo II as a result of some discussions with Russ (all posts was deleted).
I wrote a test code with both mapping variants for SPDIF on data6 and I2S.
As I can change all register settings from the IR remote these four code fragments was made to be sure no other register settings interfered.
The result was partly unexpected as the Buffalo style input mapping introduced the unlock problem when playing I2S at 352.8k using normal filter, slow slope, OSF enabled and 7bit quantizer.
Only four unlocks during one melody, but that was the first unlocks for the last year. It might have been coincidental, but I changed nothing else than loading new code.
One of the questions was if the input mapping have effect on how the quantizer/true/pseudo modes reacts to changing the phase/polarity.
I have checked this before and I got the same result now.
7bit quantizer mode are the easiest to check as there will be no audio when the phase/polarity are inverted when the Buffalo input mapping are used - this affects both I2S and SPDIF.
Also all FIR / IIR / OSF modes was affected of the input mapping.
With the default input mapping the phase/polarity can be inverted in all quantizer/true/pseudo/FIR/IIR/OSF modes.
If this is tested on a Buffalo II only half of the DACs will be used with I2S with the default input mapping - all DAC will be used by SPDIF with both input mappings..
Old 28th December 2010, 06:07 PM   #1683
Russ White's Avatar
On Bufallo II you can do all quantizer setting, but all except 6 will require pseudo differential. This is perfectly normal. Polarity changes are also easy, they just require a little thinking. I am sure you can figure it out. I did it for dual mono support.
The fact is you just have to know how the inputs are connected (which I just shared) and work from there. Pretty simple really. Use the DAC as designed and you will be just fine.
I am not going to take any more of my time to correct you.
Audio
Old 28th December 2010, 06:58 PM   #1684
There is no need for you to correct my findings.
The "thinking" to sort out the alternate settings for polarity changes with the Buffalo style input mappings was not the issue - the issue was the conditional code needed to support this on the fly from the IR remote together with the ability to change all the other settings independently.
When the default input mapping works perfect and identical with all other settings - why waste time on the issue - Buffalo will not be supported, but that have never been the intention...
I am but curious to your comments regarding the 7 and 8bit modes.
I will check my code again and verify all register settings regarding the true/pseudo modes...
Old 29th December 2010, 03:42 AM   #1685
qusp is offline qusp  Australia
qusp's Avatar
RayCtech, I need to be clear, the dac I posted is not my design, this is the teflon version ackodac AKD12P, I may have 4 of the only 6 made in my possession, the only ones sold to the public so far and had some small measure of input into design choices, but not their implementation.
also perhaps off topic as this is a ES9012 design, although there is a 9018 multichannel version in the works
Old 30th December 2010, 08:15 PM   #1686
glt is offline glt  United States
I reprogrammed the DAC to match the BuffII input wiring and indeed sounds real good.
But the locking problem is still there, and in my set up, it goes (mostly) away with DPLL BW=medium-low
In addition, the locking problem is much worse if the DAC is cold (right after power on). After power on, the problem diminishes until it reaches a steady state.
One peculiar result is the frequency reported by the DPLL register:
With 44.1 material
SPDIF input, DPLL register reports 44,105 Hz
I2S input, DPLL register reports 44,079 Hz
I had measured the bitclock of the I2S output to be 2,822,470 Hz; at 64fs that is 44,101 Hz
Is the DPLL using the wrong frequency to lock and thus the lock problem? (just a question since I know nothing about DPLLs)
the discussion above on quantizer is over my head. (The Sabre32 data sheet says nothing about setting quantizer values). Does quantizer setting has any bearing on the lock problem?
www.hifiduino.wordpress.com
Old 30th December 2010, 08:44 PM   #1687
Russ White's Avatar
No, the quantizer does not effect that at all.
I found exactly same as you and if you look carefully in the code I sent you will see how I addressed it. You may want to take this up with my offline. As I am more willing to share that info privately.
Audio
Old 30th December 2010, 08:48 PM   #1688
Ooops, I made the wrong calculation in the dpll register, the reported frequency is 44104 which matches the one reported by spdif....
Sorry about that.
Old 2nd January 2011, 06:00 AM   #1689
Bunpei is offline Bunpei  Japan
Default DPLL Bandwidth setting for DSD
Recently in Japan, some diy people has been trying a DSD input for ES9018 based DACs, for example, Buffalo II, Fidelix CAPRICE. Their DSD sources are USB Audio interface board developed by ElectArt or diy-tapped commercial SACD players.
Two of them reported that no better DPLL bandwidth setting is available than "medium-low". I guess qualities of their sources are not so bad.
They also reported that they tested a dual "all mono mode" configuration of ES9018 for DSD and got better results than those of the usual "stereo mode".
Anyway, ES9018 based DACs are rapidly gaining good reputations here.
Old 4th January 2011, 01:30 PM   #1690
Originally Posted by RayCtech View Post
With the Sabre32 DAC I can run the minimum DPLL bandwidth with 192k/24bit on SPDIF and 352.8k/32bit on I2S.
This requires an update:
My code for Sabre32 register control have been revised several times lately and as I already have reported I experienced the UNLOCK problem intermittently shortly after loading new code.
I have now completely rewritten the code for Sabre32 register control and can verify that I now also have the UNLOCK problem constantly
The possibly good news are that I found the root to the cause to why the old code only experienced the UNLOCK problem intermittently when loaded and then the UNLOCK problem went away...
The UNLOCK problem stopped when a illegal/not supported register setting stored in the EEPROM was loaded into the Sabre32.
I am now investigating what this settings actually affects and to possibly find the cause to why it stopped the UNLOCK problem...
When the new code was rewritten I included support for all possible register settings. Due to this I have also included support for Buffalo input mappings and this is now a selection on the IR remote. I have also included a status display dump to the LCD where all register settings are shown.
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
