ESS Sabre Reference DAC (8-channel) - Page 139 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th April 2009, 07:24 PM   #1381
audioman54's Avatar
Default LME49713
Hi Everyone,
A Current Feedback Opamp requires a specific value of feedback resistor. Usually 1.2k to 1.5k ohms. They also work better for audio in the inverting configuration. It is the best sounding audio opamp I have used but only where proper HF layout and power supplies are used and a low value input resistor can also be used.
Other wise the LME49710 is the next best choice and since it is a VFB opamp it is a little easier to implement. However it still requires proper HF layout and power supplies or it will oscillate.
I can promise you that if you can make these devices work in your designs then you will be more than happy with the sound quality. We have had a lot of people/staff (one hard core tube guy) listen to these devices in my prototype designs and we had 100% agreement on the improvement in sound quality over other opamps that have been around for quite awhile.
Big note however...The metal cans ALWAYS sound better than the plastic packages and you should NEVER use 4815/4915 three terminal power regulators in any high quality audio designs.
Best "Out of Work in SI Valley" Regards,
audioman54 / Mark
Old 18th April 2009, 09:49 PM   #1382
Originally posted by nagaesan
Next Friday night and Saturday afternoon, I hold DAC audition party.
Hi nagesan,
Can you report on your audition party?
Thanks,
Dave
Old 27th April 2009, 10:19 PM   #1383
Diy buddies do you think it is possible or worth it change an ES9006s present in a little 7.1 soundboard (Samsung BD-P2500 bluray player) for a ES9008S ? Will it be pin and firmware compatible ?
TT
Old 27th April 2009, 10:38 PM   #1384
matejS is offline matejS  Slovenia
Default Sabre I2C read
Hi, all!
Has anyone succeeded to do a I2S read (i.e. registers 28-31)?
Datasheet does not describe reading, only write. Write works flawlessly. For write (register, value...) has to be sent, but what for read? Is it register expected before?
Thanks,
Matej
Old 28th April 2009, 02:47 AM   #1385
Default Re: Sabre I2C read
Originally posted by matejS
Hi, all!
Thanks,
Matej
Hi Matej,
Here is the sequence for a read
Start--->0x90(write)--->0x1C(Reg28)--->Start--->0x91(read)-----> (read the byte)------>Stop
You must first write to the Sabre the address you want to read.
Hope this helps.
Dustin
Old 28th April 2009, 03:52 AM   #1386
glt is offline glt  United States
Dustin, any info on how to get the datasheet? Thanks.
Old 28th April 2009, 04:39 AM   #1387
I believe you have to go through the chip distributor. (Brain Shaw in the US)
Dustin
Old 28th April 2009, 07:47 AM   #1388
Zoran is offline Zoran  Serbia
I have some Q,
about Sabre ES9008 I-outputs :
Are they Current Source Output or Current Sink Output type?
Which one of theese two diagrams, I uploaded
shoud be better for the passive I-to-V conversion?
Which value is the lowest value of passive R iv that I could apply,
and not to damage dac chip?
Is the lower value of RIV lowering the distorsion for ES9008, same like in
for instance pcm63 and tda1541 dacs?
Or not?
I put, just for the test 1K (at each dac Iout, each -,+... )
the chip remain the just slight warm...
could someone answer please?
thanks
Old 28th April 2009, 09:08 AM   #1389
Javin5 is offline Javin5  Switzerland
Hello Dustin
A question on the ES9008: Does the selection of either slow or fast rolloff work both with SPDIF and I2S inputs?
My setup with SPDIF-input somehow seems to be stuck to slow rolloff.
Kurt
Old 28th April 2009, 09:46 AM   #1390
Default Re: Re: Sabre I2C read
Originally posted by dusfor99
Hi Matej,
Hope this helps.
Dustin
Thanks, Dustin. It works!
My setup is 24.576Mhz clock, I2S input , SPDIF source from HK HD970 CD (most likely 48kHz).
Read DPLL_NUM (MSB-LSB) = 0x20 0x00 0x4C 0x00
If I use equation from datasheet I get strange results... however if I use the following equation:
DPLL_NUM / (2^32) * 24 576 000 / 64
I get 48 001.7395
Is there an error in datasheet?
Matej
Copyright 1999-2017 diyAudio
