| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1211 |
kooda wrote;
>I sent you an email yesterday, with no reply. Did you get it? Yes, but when I got your e-mail, JAPAN was midnight. Sorry to reply. |
#1212 | |
1) Correct. 2) We are aiming to get a new design out as soon as practical, but our schedule is dictated by some outside factors beyond our control, so the best we can do is keep our site updated with news about coming attractions. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#1213 |
Counterpoint boards have arrived, ready to start testing...
Twisted Pear Audio |
#1214 |
excellent news Brian...
Any chance we can get these boards for testing? |
#1215 | |
not until we test them first. [EDIT]: I just realized I posted this in the wrong thread. Sorry about that.
#1216 |
Hello, may I ask a question?
Does the Counterpoint board have active type(OP-AMP) of I/V conversion stage? |
#1217 |
I saw the close up photo, it seems like voltage out from ES9008S.
DIY people in this forum, do not like OP-AMP I/V stage? |
#1218 |
No. It is discrete.
#1219 |
I am sorry, the Counter point DAC have discrete active I/V stage, and this is not ES9008S?
#1220 | |
The Counterpoint is indeed intended for the ESS9008/ES9018, but it would work equally well with any current output DAC. It is meant specifically our Buffalo DAC. I am not sure how you would make it work with the EVAL board as you would need to exclude the on-board I/V stage. Probably would require some board surgery. ![]() There is a quad opamp on the board, but it is only used to set bias voltages and act as an integrator. It does not do the actual I/V conversion. It could be called a type of fully symmetrical folded cascode current conveyor design, but not a classic current conveyor. I am really not sure how to classify it. One cool feature is that the output can be balanced even if you use a single ended current source, but you can take only one end and use it single ended with almost no THD penalty. I can't wait to fire it up and give it a rip outside the simulator. The earlier prototype worked very well. So hopefully the testing goes ok. Cheers! Russ
