ESS Sabre Reference DAC (8-channel)
Old 25th December 2008, 09:56 AM   #1131
tritosine is offline tritosine
well , i rephrased Gordon's msg (without his approval) , i definately think he is talkin bout an ADC:
- ESS released yesterday the 32 bit version of the Sabre, AND, you heard it here first: THE first ever 32bit ADC...
32 bit wordlength is more common than the 6bit 5mhz comnig from a PCM4222 so it makes enough sense to me... I also remember Dustin said it'd be fun to start out with an ADC project, esp since even audio precision 2 uses bog standard cirrus converters.
Old 25th December 2008, 01:41 PM   #1132
Telstar is offline Telstar  Italy
/Me would like a 32 bit DAc version of the Sabre, it would allow for digital volume control.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 25th December 2008, 02:50 PM   #1133
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
The Sabre8 also has digital volume control. It does it at a higher bit rate than the 24-bit output (IIRC, it's done at 44-bit resolution). I am not sure the Sabre32's volume will be any different, but it's possible.
Old 26th December 2008, 01:02 PM   #1134
This is very interesting, i must have missed something then
So it coudl be done in hardware in the dac without loss.
But how could it be implemented in software without the obvious resolution problems? Would that be possible?
AFAIK connected to a computer, the Sabre is seen as a 24 bit sound device.
Old 30th December 2008, 10:17 PM   #1135
diycore is offline diycore  Ireland
About ES9008S in hardware mode.
It is stated in the datasheet that in this mode, the chip would only accept I2S data. And the default register for bit width is 24bit. Does this mean that hooking it up with USB receivers like PCM2706 is not possible? PCM2706 has 16bit I2S output.
Also for applications using USB receiver and PC as a digital source, I do not know if the output would be 44.1kHz or 48kHz, the choice of system clock seems difficult to decide. Some previous posts suggested the system clock needs not to be a multiple of the digital source, but the clock should be as fast as possible.
Old 30th December 2008, 10:25 PM   #1136
Russ White is offline Russ White  United States
Russ White's Avatar
I would not advise using the chip in hardware mode at all.
Its automuting will drive you nuts.
The Sabre32 resolves all the issues that made hardware mode difficult with the Sabre8.
If you must go hardware mode then I would use the Sabre32.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 30th December 2008, 11:57 PM   #1137
Oh man. I'm so tempted to start a project using this chip. But the microcontroller part is a real downside for me.
Any idea of the ETA of the new chip?
Old 31st December 2008, 04:59 AM   #1138
rfbrw is offline rfbrw
Can you get the old chip without jumping through hoops ?
Old 31st December 2008, 06:31 AM   #1139
TimmyMac is offline TimmyMac  Canada
Yes, there's a group buy thread that's a few weeks (months?) old. MOQ is 5, and the chips cost around $50 each.
Old 31st December 2008, 08:50 AM   #1140
There are two suppliers for UK and Ireland, if you meant if I can get ES9008S or not.
ESS Sabre Reference DAC (8-channel)Hide this!Advertise here!
