Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th November 2010, 05:32 PM   #51
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
yes, but I have excluded also the output stage
see
Hi-Resolution System 192KHz 24bit with EMU 0404 USB
Old 26th November 2010, 08:33 PM   #52
From the tests, I see that you constantly managed to worsen the output quality of the 0404.
Swapping the opamps with better ones would be a better aproach IMO.
Old 26th November 2010, 09:22 PM   #53
Pano is offline Pano  United States
Pano's Avatar
For 1KHz he does show higher distortion. Tho it isn't awful and should not be audible.
But the real test is at >1KHz. That's often where opamp output circuits start to get nasty. Try 3KHz and its octaves. There may be some real differences. Ditto with multi-tone and IMD.
Take the Speaker Voltage Test!
Old 26th November 2010, 11:13 PM   #54
Come on... I doubt there is any difference between 1kHz and 3kHz on any decent OpAmp. And past 10kHz... you don't hear the harmonics anymore.
Old 26th November 2010, 11:19 PM   #55
iko is offline iko  Canada
iko's Avatar
Did I mention that I replaced most of my opamps with top notch ones?
Old 27th November 2010, 03:11 AM   #56
I did play too replacing 5532 in different other equipments with NJM2068. Altough, not bad, the LM4562 is a way better choice.
Old 27th November 2010, 03:20 AM   #57
Pano's Avatar
Define "decent."
Measure and see. You might be surprised. I was.
Old 28th November 2010, 12:45 AM   #58
Well, for me LM4562 are decent. And all I need. Tube sounds worse to me - at least the ones that I heard.
Old 30th November 2010, 05:56 PM   #59
Anyone tried LPF capacitor output stage?
Old 30th November 2010, 06:26 PM   #60
I can't tell I have heard the effect but the harmonics above audibility do create an audible effect.
Think about the 19kHz + 20kHz intermodulation test.
These two frequencies are sufficiently high enough that most listeners cannot hear the fundamentals. I'll bet most can hear the in band distortions readily.
EMU 0404 Sound Card tripathdude Digital Source 5 23rd May 2008 04:46 PM
FS: E-mu 0404 USB external sound card Jack Hidley Swap Meet 2 14th March 2008 01:00 AM
X-over modification hermanho Multi-Way 1 20th February 2006 06:52 AM
Modding my EMU 0404: Can someone please verify bg4533 Digital Source 4 11th November 2004 09:32 PM
Help CDP-Modification wfmali Digital Source 0 1st June 2003 05:03 PM
Copyright ©1999-2013 diyAudio
