E-MU 0404 USB Modification? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd October 2009, 05:22 PM   #21
iko is offline iko  Canada
iko's Avatar
Originally Posted by fmak View Post
There is no point in modding this unit unless one can get rid of the 110kHz generated by the switching power supply inside.
Which smps inside are you referring to? Inside the 0404?
Old 3rd October 2009, 05:50 PM   #22
Crassus is offline Crassus  Finland
I'm not sure if I understand what you are talking about? 110khz? Could you perhaps point to certain components on the PCB? Anyway, I'm planning on using an old ZIP-drive PSU instead of the wall wart that came with the 0404. Don't know if it makes any difference but testing it doesn't cost more than the connector.
Even on spdif output with an exteranal dc supply, the unit is far inferior sounding to a $75Musiland US 01 which is capable of 192k output.
I haven't seen the output on an oscilloscope but to distinguish between two devices I would suspect that maybe the difference has something to do with the device firmware/drivers. I doubt that there's a difference that would remain in ABX testing...
The software on the 0404 also sucks and this is typical of Creative who supplies hundreds of MB of Junk Software which is not necessary.
Sure, the SW package is a bit large but the SW seems solid. I have never had problems with the 1212M and the 0404 seems to be working just fine once I defined the sample rate in Windows correctly (so that the device doesn't try to change the sample rate on the fly... I have a bit of a mixed setup).
Old 4th October 2009, 05:56 PM   #23
Look at the input voltage terminals with a good scope; doesnt matter what you use as dc source, the 110kHz modulation is there.
Old 4th October 2009, 05:58 PM   #24
Inside where it goes from 5V to whatever voltages are needed. there is an approx 110kHz modulation of what is fed in as dc.
Old 29th October 2009, 02:52 AM   #25
Hi, I'm interested in extensively modding my 0404 USB, and for that I need its circuit schematics, as detailed as I can get them. If anyone has these, I would appreciate a PM or a link to them.
Old 12th January 2010, 06:43 AM   #26
Since I have a Sennheiser HD-650, I am quite interesting in this discussion. Talking about DC-DC converter, it works just like a switching mode power supply: we can convert the voltage up, down or even revert the polarity of the input 5V supply. From what I read so far, it looks like this "SMPS"'s working frequency is too low: 110KHz. This is definitely a good sound killer without any doubt (even it is working on 10MHz freq, you still can hear the difference, trust me)! However, using some ferrite bead, ceramic caps around those DC-DC converter (of course, you need to cut the traces), I think it is still possible to improve 0404 USB to a quite decent headphone amp. Again, how to implement this modification, we need to get a schematics first. If you feel the sound is lean and dry, that is what we are talking about: 110KHz DC-DC converter operating freq. and its higher order harmonics.
Old 5th February 2010, 09:33 PM   #27
Has anyone found a service manual or schematic of the EMU ? I would also be willing to buy one if you know a place that sells them.
Old 14th February 2010, 01:21 PM   #28
Default Schematics for EMU 0404 USB
I am also seeking schematic and block diagram. I am using emu 0404 usb and Tracker for measurements, primary reason is that on 44.1kHz, 24bit, MIN gain settings I get fairly good dynamic range. Tracker gives me better isolation fro 110V line, while its input noise is considerable worse than EMU 0404 USB.
Recently I deal with recording signals in frequency band below 0.1Hz - 0.01Hz. I am desperate enough to get into the endstage circuit in order to avoid all coupling capacitors and bypass low quality circuits between Lin In - ADC. Has anyone injected signal directly into ADC? Improvement noticed?
Old 3rd March 2010, 08:25 PM   #29
iko's Avatar
Bump, I've setup a wiki here
E-MU 0404 USB mod wiki - diyAudio
to help anyone that's interested in modifying the 0404 usb. Anyone with any hard data please feel free to contribute.
Old 3rd March 2010, 08:45 PM   #30
JimT is offline JimT  Canada
Ikoflexer,
I posted recently about a noise issue with the 0202. I expect it is also a problem with the 0404. It may be of use to you.
http://www.diyaudio.com/forums/solid...rments-12.html
Jim
EMU 0404 Sound Card tripathdude Digital Source 5 23rd May 2008 04:46 PM
FS: E-mu 0404 USB external sound card Jack Hidley Swap Meet 2 14th March 2008 01:00 AM
X-over modification hermanho Multi-Way 1 20th February 2006 06:52 AM
Modding my EMU 0404: Can someone please verify bg4533 Digital Source 4 11th November 2004 09:32 PM
Help CDP-Modification wfmali Digital Source 0 1st June 2003 05:03 PM
Copyright 1999-2017 diyAudio
