| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | |
Huh, I would swear TDA1545A is NON I2S.... "compatible with most Japanese inputs formats" the datasheet says. |
#22 |
Impossible, for the reason that I have a hand-built NOS DAC using TDA1545A and STA120 (similar to CS8414), and it's definitely in i2s... The STA does not even know WTF is EIAJ
#23 |
#24 | |
http://www.pinkfishmedia.net/forum/s...18&postcount=2 EIAJ to I2S converter and vice versa Anyone care to take a stab: TDA1543 TDA1543A TDA1545 TDA1545A TDA1541 TDA1541A |
#25 |
How I do lament the passing of the good old days when you had to at least have a passing acquaintance with the topic at hand before you were allowed even a sniff of a datasheet not least because they came in 1000 page tomes and you had to ask for them. That everyone and his dog is allowed access these days does not change the fact that these are specialist publications and some prior knowledge is assumed. Perhaps next time I feel a little discomfort and wish to self-diagnose I should go wailing to the medical authorities about the excessive use of latin and compound words in their texts.
#26 |
Thank you for reply
The tda1545 "A" or not, only accepts EIAJ |
#27 | |
#28 |
#29 |
Toni,
The board layout in your post #6 is my implementation of John's schematic. John would have, undoubtedly, built it better. For this implementation, the master clock (on this board) sits in the DAC box proximate to the dac input pins. It sends the master clock back to the transport; in this case a squeezebox 2. The SB2 outputs left justified format, not I2S. Hence, there is add'l complexity on the board you referenced (unnecessary for those with transports that output i2s) to convert the left justified format to i2s, because my dac tda1541 is able to input i2s, not left justified format. Once the signal is received by the dac box, it is converted to i2s and re-synched by the same master clock. Jitter at the dac pins is essentially the jitter on the output of the clock--in my case a Tent clock which is spec'd at under 3ps. The frequency is 11.2896 for both dac and transport, everything is synchronous. It sounds wonderful and transformed my dac. As you can see, this circuit is pretty specialized. For more details I created a simple website mainly for squeezebox users (below). I'm not familiar with the tda1545 chip and its permutations. http://home.socal.rr.com/audio_gestalt/default.htm
Cheers ~ Mike |
| supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 | smartech | Vendor's Bazaar | 1 | 10th April 2011 11:02 AM |
| Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. | Julien_M | Swap Meet | 5 | 25th January 2009 12:03 AM |
| PCM1794 DAC and CD pro2 clock | galouche | Digital Source | 0 | 9th July 2007 11:00 PM |
| 33.86 Mhz clock on CD-Pro2 | Peter Daniel | Digital Source | 3 | 25th October 2005 11:12 PM |
| External clock to CD-PRO2 | kenev | Digital Source | 59 | 5th October 2005 09:58 PM |
| Page generated in 0.26258 seconds (37.89% PHP - 62.11% MySQL) with 11 queries |
