One clock for CDM12 Pro2 and Nos Dac TDA1545
Old 29th October 2007, 09:13 AM   #11
rfbrw is offline rfbrw
Originally posted by gochtoni_toni
I will recklock the bitclock with 11.xxxmHz
I don't think it is a good idea to reclock 2.1168 MHz or 8.4672 MHz with 11.2896 MHz.
Old 29th October 2007, 09:32 AM   #12
gochtoni_toni is offline gochtoni_toni  Germany
Bitclock from the pro2 is 11.xxxMhz same with Cs8414 Receiver
look at datasheet from the SAA7324 Contoller
http://www.daisy-laser.com/products/.../SAA7324_2.pdf
kind regards
Toni
Old 29th October 2007, 11:07 AM   #13
kind regards
Toni
I see. Have a look at page 18, not that it matters. The CDM12 PRO2 uses the SAA7345.
Old 29th October 2007, 12:25 PM   #14
On page 18 is the SAA7324
Old 29th October 2007, 03:46 PM   #15
vt4c is offline vt4c
Hello Toni,
I had a couple of CDM12 Pro2 loaders (Ind. Pro2, Pro2M) and I observed that some loader are using 33.86Mhz and some are with 8.4672MHz crystal.
Just thought that you might be interested to take note of...
Old 30th October 2007, 08:57 AM   #16
Hello VT4-c
Yes, you can use 8.xxx, 16xxx and 33xxx Mhz at the drive. But the TDA1545 dont work with this frequencys.I think they need the multiple of 44.1 kHz. I find nothing about this on the web.
regards Toni
Old 3rd November 2007, 05:34 AM   #17
Hello Toni,
I would suggest that you connect the I2S interface directly from the CDM12 Pro2 loader and feed it to the respective interface pin on the TDA1545 chip. It will work this way and perhaps synchronous reclocking it at a later date if you have the 'itch' to tweak
Old 5th November 2007, 05:10 AM   #18
VT4-C thank you for reply
In the way you suggest are a benefit of a Tentlabs or Audiocom clock at the controler-chip of the CDM Pro2?
Old 5th November 2007, 12:33 PM   #19
Hello Toni,
Use the Tentlabs or Audiocom clock to clock the CDM12 Pro2 loader....
Old 26th November 2007, 06:19 PM   #20
Vikt0r is offline Vikt0r  Ukraine
Send a message via ICQ to Vikt0r One clock for CDM12 Pro2 and Nos Dac TDA1545
Originally posted by vt4c
Toni,
The CDM12 Pro2 drive puts out I2S in default mode. You'll need to configure the CDM12 Pro2 to put out EIAJ format that the TDA1545 recognise.
Wrong!
It's the TDA1543 which has versions A/non-A with EIAJ/I2S interfaces respectively. The TDA1545 only comes in A version, with i2s only.
One clock for CDM12 Pro2 and Nos Dac TDA1545Hide this!Advertise here!
supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 smartech Vendor's Bazaar 1 10th April 2011 10:02 AM
Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. Electro3000 Swap Meet 5 24th January 2009 11:03 PM
PCM1794 DAC and CD pro2 clock galouche Digital Source 0 9th July 2007 10:00 PM
33.86 Mhz clock on CD-Pro2 Peter Daniel Digital Source 3 25th October 2005 10:12 PM
External clock to CD-PRO2 kenev Digital Source 59 5th October 2005 08:58 PM
