Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd August 2003, 09:24 AM   #61
ergo is offline ergo  Estonia
zygibajt, with Behringer if lucky you can tame the room standing waves and such problems. For reflections, decay times etc. still it does not do a lot, so additional treatment might still be very useful.
Ergo
Old 23rd August 2003, 09:28 AM   #62
Difficult question. Purist would probably prefer room adjustments. I think it is quite difficult to finetune these adjustments, so you get rather crude "corrections".
Digital adjustment should be more easy (at least for 1 listening spot, however you have plenty presets for different spots),
I try to do the low end adjustments ( < 200 Hz) with the Beringer (in digital domain) and the rest with carpets, curtains etc. Ofcourse unless you have a digital crossover the mid/high signal still passes the DSP.
If you prefer analog all the way I guess room adjustments is the best option (or very expensive analog equalizers).
Edit .and indeed as ergo noted it only levels the signal level and doesnt cancel reflections, etc.
Is that all there is?
Old 23rd August 2003, 10:22 AM   #63
pinkmouse's Avatar
I would go with as much room treatment as you can get away with, then use the Behringer to ameliorate the rest.
Most room treatment methods will run into SAF, but bear in mind, you can get good results just by moving a bookcase or similar.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 23rd August 2003, 10:52 AM   #64
Thanks for the answers.They 've been very useful for me.
I must say that I have a room dedicated to hi-fi (better fi) Audio equipment,and for a couple of months have been playing with diffrent kinds of diy (but very high quality) room treatments devices.After reading this thread I started to think that the Behringer might be a miracle cure ,and it would save me plenty of work with room acoustics regular way.But I suppose that kind of miracle won't happen.Now I know that I can invest the money I would spend on Behringer in building some good bass traps or other useful devices.
One more question:
What would You recommend for measuring room response?
Any DIY idea?
Bartek
Old 23rd August 2003, 08:43 PM   #65
The best approach would be to get the room response as good as possible before fiddling with equalization.
For many, there are severe practical limitations to getting the room (and speakers) perfect.
A Behringer unit will likely help you significantly.
Petter
Old 15th September 2003, 09:03 PM   #66
JayV is offline JayV  Sweden
Question setup
I have recently bought a DCX2496 to use as filter for a triamp system, Linkwitz Phoenix or Orion. And now im thinking about buying a Ultracurve (and the mic) to get automatic room correction. (i will program the element correction, as well as the filters on the DCX before i use the room correction on the Ultracurve).
Is this a good idea? If i use digital signal from the cd to the Ultracurve, and then digital to the DCX2496, then analog to a 6 channel balanced preamp, and at last to 6 aleph2 or 6 (balanced)gainclones.
Will the sound remain good when i use digital signal all the way to the D/A of the DCX? Or will the signal degrade for each "stage"?
Party on Wayne!
Old 15th September 2003, 09:09 PM   #67
tiroth is offline tiroth  United States
You will experience some degree of degradation. I would first see if the DCX2496 is sufficient.
Old 10th January 2008, 12:50 PM   #68
I`m planning to buy one of these and incorporate it in my home cinema, somehow..
Can`t figure out the best way to do it.
Should I connect it to the tape monitor rca in/out, with a DI box to convert the -10dBu signal to +4dBu before and maybe after the equalizer? Have read that it does not give a good result using
just the line level signal.
Behringer DEQ24/94 UltraCurve Pro $200 Zero Cool Swap Meet 1 19th March 2007 11:09 PM
FS: Behringer DEQ2496 UltraCurve Pro Rescue Toaster Swap Meet 3 4th February 2006 01:38 AM
Behringer Ultracurve DEQ2496 - ways to use it? paulspencer Multi-Way 28 25th December 2004 11:56 AM
For Sale: Behringer Ultracurve w/digital I/O Bill F. Swap Meet 13 9th February 2004 03:23 PM
Behringer UltraCurve Pro DEQ 24/96 Intelonetwo Swap Meet 5 7th October 2003 06:21 AM
Page generated in 0.09516 seconds (79.80% PHP - 20.20% MySQL) with 10 queries
