About a discrete I/V preamp for a no-os TDA1541 Dac - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th September 2007, 08:59 PM   #1
Default About a discrete I/V preamp for a no-os TDA1541 Dac
Hello
I want to made a discrete I/V preamp for a no-os TDA1541 Dac, here is a circuit. The 51R resistor are for the I/V conversion.
Do it need a nfb ?
What is the formula to calculate the value of L1 L2 C1 for a bessel 20khz low pass filter ?
Thank
Gaetan
Old 10th September 2007, 09:37 PM   #2
Hello
For the bessel filter, I was mean a second order type.
Thank
Gaetan
Old 11th September 2007, 12:15 PM   #3
Hi Gaetan,
Just a side note: the 51R will be too much for the TDA1541A, because the full output current of 4 mA will drop 200 mV on it, while the data sheet permits 25 mV only. The result is distortion. Also the idle current is 2 mA that is equivalent to 0 V analog output. This is likely to create a click when the CD starts or stops playing.
Laszlo
Old 11th September 2007, 01:49 PM   #4
Account Disabled
what about HF imgaes coming out of NOS dac arent those shouting in some way (Into the I/V) (...)
Old 11th September 2007, 05:03 PM   #5
Hello
If 51R are too much, which value you suggest ?
For the HF from the 44khz, I can filter much.
My circuit seem not very good.
I was think to use op-amps like THS4032, LM6172 or AD625, but op-amp may not sound as good as a good discrete circuit.
But with op-amp I would use with a 3rd order modified Bessel filter as illustrated in the following image.
Thank
Gaetan
File Type: jpg 19khz low pass 3nd order filter-6-b.jpg (77.9 KB, 648 views)
Old 12th September 2007, 08:36 PM   #6
I just use an LM6172 as recommended in the TDA1541A datasheet, followed by a 3rd order passive filter, but for NOS, I don't bother with a filter.
I also want to go discrete, but I am actually quite happy with opamp IV for now. I've tried various opamps, and I've returned to the LM6172. Others are also good (I also like the LT1361), but I prefer the '6172 personally.
Opamp IV is a good stop gap on the way to going discrete, and shouldn't provide an awkward load - like the humble resistor.
Phil
Old 12th September 2007, 09:28 PM   #7
If you want to use a resistor for I/V with the TDA1541, you must keep the compliance voltage below 25mV as noted. So the biggest resistor you can use is just 0.025/0.004mA = 6ohms.
Which isn't very big.
The next problem is simply that your maximum audio signal output is 24mV peak-peak, so you need a gain of 100x to bring this up to line level. Doing this and preserving a decent signal-to-noise ratio will be fun...
I've stayed with more traditional active circuits.
Old 13th September 2007, 12:54 PM   #8
What about eliminating the I/V resistor and feeding the DAC current output into the source of the FET (or emmitter of the transistor)? It needs proper biasing, though.
Old 13th September 2007, 04:13 PM   #9
Hello
Since the discrete fet circuit need to much mods to work good, I will use an op-amps. But I don't know for now if I will use passive or active I/V conversion, some say that passive sound better.
Thank
Gaetan
Old 14th September 2007, 11:38 AM   #10
Active opamp I/V can be very good. I used an OPA627 with 1.5 kohm feedback and an 1 uF PP output capacitor, it sounded very good. If you want a "better" I/V stage, consider a transformer/tube circuit.
Where can I get a pcb for a discrete GC preamp? raypalmer Chip Amps 2 27th January 2009 10:45 AM
Discrete guitar preamp suzyj Instruments and Amps 132 26th June 2008 03:41 PM
which discrete preamp ? sopapo Solid State 12 13th January 2006 08:11 PM
Simple discrete preamp OliverD Solid State 69 22nd July 2004 10:14 PM
Copyright 1999-2017 diyAudio
