Discussion on what materials to build speakers out of - Page 20 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 22nd April 2007, 06:27 AM   #191
frugal-phile(tm)
planet10's Avatar
Originally posted by MJL21193
The Q factor or quality factor compares the time constant for decay of an oscillating physical system's amplitude to its oscillation period.
True, but it is not the Q i am talking about. By high Q i am talking about the energy required to stimulate a panel resonance. This implies that a large amount of energy in a very narrow bandwidth needs to be injected into the panel to make it vibrate.
The energy is quickly released/dissipated because with music we will not have a continuos input of energy, it will be bery transient. As soon as the energy in the panel falls below a certain amount, the resistance of the panel to vibrate at any but that very narrow bandwidth will quickly damp the resonance.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd April 2007, 06:53 AM   #192
frugal-phile(tm)
planet10's Avatar
Originally posted by rick57
fwiw some math on the relationship between size, mass, thickness and MOE, and panel resonant frequency
Thanx for digging that out... i would have read that when Hu 1st posted it some 5 years ago, and it would have played a role in the evolution of my box building philosophy...
dave
Old 22nd April 2007, 08:14 AM   #193
Ricky is offline Ricky  United Kingdom
I should like to add my tuppence worth to this.
I have read with interest that people think that MDF "sucks the life" out of a loudspeaker. I think that's a bit extreme but it certainly can add a cold/clinical edge to the proceedings. Hardwoods, Oak and Beech in particular seem to give a more natural sound. The only problem is that a hardwood will move according to humidity.
At Arcaydis, I designed a cabinet in solid American White Oak and sold 20 pairs to a Canadian distributor. Every single pair came back. Why? Not because there was anything wrong with the speakers. The average humidity in Canada is 6%. The Oak literally "dried out". I found a remedy by laminating 8mm Oak to 12mm MDF in a flat press. Then I got the cold clinical edge.
So here's my tuppence worth. Decide what thickness cabinet you want. Let's say 30mm. That's 12mm of hardwood flat pressed to, wait for it, 18mm double density chipboard. One tip. Put a layer of veneer on one side of the chipboard. This will remove the "bendy spoon" element.
Right. That's me done. Wish you all well.
Ricky.
Old 22nd April 2007, 08:25 AM   #194
frugal-phile(tm)
planet10's Avatar
Maybe in the winter in the flatlands... in the winter here it is well above 50% and a lot less in the summer...
dave
Old 22nd April 2007, 08:28 AM   #195
Svante is offline Svante  Sweden
Svante's Avatar
. . Iíve seen figures that the energy of a large orchestra live by octave, eg over 125-250 hz is about 4 dB more than 1-2 kHz, loosely suggesting a modest benefit in pushing panel resonances up 1khz plus.
Originally posted by planet10
I don't know the exact math, but IIRC the amount of energy available to excite a resonance is inversly proportional to the square of the frequency...
The part of excitation that originates from the sound pressure inside the box is largely proportional to 1/f≤ if the radiated sound is flat. Besides the direct mechanical excitation from the driver, the sound pressure inside the box is the dominating source of excitation. The pressure outside the box is typically neglectible.
So pushing the a resonance upwards by two octaves, using the numbers above should decrease excitation by 24+4 =28 dB.
In the simulation below it can be seen that the pressure inside the box (dashed) is tilted by approximately -12 dB/oct (=1/f≤) relative to sound pressure at 1m (solid).
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 22nd April 2007, 08:32 AM   #196
Hi!
Agree, but had some good result with with low density also!
Easier will be a layer of lacquer (and cheaper) instead of veneer on the back. The furniture industry use glued paper.
There exists a ratio of how thick layer of glue and paper it has to be to avoid warping in long term. Have to ask one of our customers about that.
John,
did you finish the two boxes, mdf/bb and measured them?
Cheers
Peter
Old 22nd April 2007, 08:36 AM   #197
Hej Svante!
Could it be Svante as in the Edge sim?
MVH
Peter
Old 22nd April 2007, 08:37 AM   #198
dave
Hi Dave.
You have just proven the point against using just hardwood. I found that the composite route faired well. Has to be flat pressed with PVA tho.
Ricky
Old 22nd April 2007, 09:12 AM   #199
frugal-phile(tm)
planet10's Avatar
Thanx for that, it puts a real "face" on things... as well one can expect a bit more attenuation if the panel resonances get up into the region where the air-space damping is effective.
Another thing it twigged is that one wants to avoid putting the panel resoance into the same place/frequency as a standing wave.
dave
PS: when John Atkinsom measures panel rsonances with his little device... what kind of device is that and where would one get one (or get something to repurpose)?
Old 22nd April 2007, 09:50 AM   #200
The actual air moving inside the box actually has much, much less energy to drive a panel resonance than the mechanical mechanism that attaches the driver to the box...
Iím not suggesting youíre wrong, but has this been measured?
On another aspect, might the ratio of internal sound energy to panel resonance differ for sealed and vented? Or not because were so far above the vent's range
Cone Materials Discussion J.R.Freeman Multi-Way 46 11th May 2009 01:22 AM
Other ESL build with simple materials available from local grocery stores Audio_idiot Planars & Exotics 69 7th September 2006 05:52 PM
Copyright ©1999-2017 diyAudio
