| Construction Tips Construction techniques and tips |
#111 |
This is how it looks from the other side (first order filters)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#112 | |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#113 |
The complete speaker also contains two woofers (12 and 15" Focal Audioms) in folded baffle setup. The boxes are made of dual layer 3/4" MDF, plastic laminate on the outside. Both sections are attached together with 0.75 x 1.5" aluminum bars. Bottom stand is also filled with sand. The whole thing is modular and easy to transport.
#114 |
Some of you may remeber those speakers from years back, but this is the latest incarnation and better than ever.
#115 |
Beautiful work Peter.
#116 | ||
I will build three boxes, of three different materials - one of MDF, one from baltic birch plywood, and the third from cheap spruce sheathing. I will construct each box from the same thickness material (1/2"). I will build each the same way - with glue and 1.5" airgun nails. They will be identical in every way. I will make one hole for a midbass driver that has a normal Xmas~5mm. I will then test each box for panel resonance, using nearfield frequency response with the mic 1/2" from the largest panel. There will be no damping material, the boxes will be empty sealed boxes. Has someone already done this and published the results? Quote:
Doesn't an undamped box add it's own colouration? |
#117 | |
...truth seeker...
454Casull posted:
![]() For my own piece of mind (I'm not going to build 3 prototypes) I will add 3/4" dowels across the interior of the case. They'll be spaced with some influence allowed to ratio's of 1.618...
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#118 | |
frugal-phile(tm)
All panels add colouration. The idea is to minimize them. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#119 | |
frugal-phile(tm)
What box are you building? Holey brace(s) are a lot more effective than dowels. dave
#120 |
...truth seeker...
Hi Dave,
The box will closely resemble this: ![]() The box dimensions will be 39" h x 7.5" wide x 14" d. It is an effort to get as much out of an RS180 pair as they have to offer. I think the dowels should be connecting the side panels.
| Cone Materials Discussion | J.R.Freeman | Multi-Way | 46 | 11th May 2009 01:22 AM |
| Other ESL build with simple materials available from local grocery stores | Audio_idiot | Planars & Exotics | 69 | 7th September 2006 05:52 PM |
