Construction Tips Construction techniques and tips
Discussion on what materials to build speakers out of
Old 17th June 2007, 03:13 PM   #491
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Hartono
I sold it because I thought I didn't have enough bass.
Mine were actively XOed to a pair of Peerless 8s. They were a pretty amazing speaker for store bought & $300/pr.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th June 2007, 03:20 PM   #492
Hartono is offline Hartono  Indonesia
dave
yes, I think the enclosure damping technique, small midbass and slotted port matched very well.
Hartono
Old 17th June 2007, 03:32 PM   #493
frugal-phile(tm)
planet10's Avatar
Originally posted by MJL21193
(within the limits of my lowly HT receiver, right Dave?).
You don't have anything better?
dave
Old 17th June 2007, 03:38 PM   #494
FRUGAL>>>>>
Old 17th June 2007, 04:41 PM   #495
Ray Collins is offline Ray Collins  United States
John,
What is the brand and type of silicon you intended to use for bonding the constrained layer?
Ray
Non Illegitimus Carborundum
Old 17th June 2007, 05:18 PM   #496
peterbrorsson is offline peterbrorsson  Sweden
Hi John and Dave, you sound like a married couple
John, I would say you put on quite an effort here! I mean in a positive way!
I've got a question about silicone. I have been using that before but gave up as it creeping out of joints long after its supposed to have dried. This was a problem particular when using paint on MDF. And above all, silicone and lacquer/paint are like republicans and democrates
Cheers!
Old 17th June 2007, 05:23 PM   #497
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Ray,
I like your signature line as I think along those lines also, but isn't it: "Illegitimi non carborundum"?
Or is that deliberate?
planet10 needs your help:
Let's help Ruth and Dave
Old 17th June 2007, 05:41 PM   #498
maduras is offline maduras  Canada
Yoo All
Use contact cement to bond your materials together.Best damping ever.Contact cement is realy neoprene rubber.Take two pieces of scrap and bond together with regular wood glue.Now do the same using contact cement.Drop on a solid surface.Gone is the ringing with the contact cement.
Cheers
The Gerry man
Old 17th June 2007, 06:05 PM   #499
Cal,
Either way is OK since both phrases are pseudo-Latin. Illegitimis is the dative plural of Illegitimus. I selected the singular since much of the time there seems to be one b*st*rd leading the attempt to "grind you/me down"?!
Ray
Sorry, I am trying to make the reply unoffensive to the censors and members.
Old 17th June 2007, 08:10 PM   #500
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Dave,
No, I don't have anything better than this receiver. I have an old (I mean ancient) Pioneer SA-6800 integrated amp that this one (Yamaha HTR-5760) replaced. The Pioneer in out in my workshop.
I have no claims to audiophiledumb.
This being a DIY audio site, I can say that I am striving to make up for any of the Yamaha's deficiencies by building the previously mentioned speakers as full active, with filters and amps of my own devising.
Whether I get results that are better than what the Yamaha (they have been building amps a lot longer than I have) will give me, that's unknown. But one thing is for sure, I'm having fun doing it.
Discussion on what materials to build speakers out ofHide this!Advertise here!
Cone Materials Discussion J.R.Freeman Multi-Way 46 11th May 2009 01:22 AM
Other ESL build with simple materials available from local grocery stores Audio_idiot Planars & Exotics 69 7th September 2006 05:52 PM
