Construction Tips Construction techniques and tips
Discussion on what materials to build speakers out of
Old 11th June 2007, 12:20 AM   #401
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally posted by planet10
Yes. Adding damping to the panels means the need for even more bracing...
Panel damping is something i've abandoned as counter-productive.
No, that's not what I mean. As you damp, you don't have to add more bracing, just use the correct amount to start with. As the resonance has been driven upwards, it will be easier to damp.
Surely, I'm not the only one who sees the logic in this.
Old 11th June 2007, 02:00 AM   #402
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Add damping to the panels walls. Adds mass with no increase in stiffness... pushes panels resonant frequency down.... bracing needs to be closer to counter this .... hence more bracing...
If the panel resonances are high and not excited then there is no resonance to damp so why try to cure a problem that doesn't exist?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th June 2007, 02:49 AM   #403
MJL21193's Avatar
dave
Make a large bell - it rings at a low frequency, difficult to halt the ringing (damp) once started. Melt this bell down and make smaller bells - they ring at a higher frequency, easy to damp the ringing.
Damping is not adding mass for nothing, it's a system for absorbing vibration. No extra bracing needed.
How is that when you drive up the panels resonant frequency, that it won't be excited? What resonances are you trying to damp in a 4" driver? How is it that the driver basket can have its resonance excited when the box panel does not?
Going back to the bell analogy, how much damping material would it take to critcally damp the large bell? If we made 100 smaller bells from it, would thedamping material for each be 1/100 of what is needed for the large bell? Most likely not, as the frequency to be damped is higher, therfore easier to damp.
Old 11th June 2007, 05:31 AM   #404
frugal-phile(tm)
planet10's Avatar
You must have missed the part where i stated, and Svante showed a chart, that the exciting energy decreases as the square of the frequency. A panel will not resonate unless a critical quantity of energy at the panel resonance is input into the panel. And if the panel is made of an inherently well damped material like plywood, it have to reach that energy threshold while the panel is draining the energy. If you get the panel resonance high enuff, there is never enuff (close to) instantaneous energy to overload the inherent damping in the panel. It is like trying to fill a container to the top when there is a big leak at the bottom and your delivery tool is a straw. Not being excited, it as if the panel has no resonance at all... so again, why would i complicate things to fix a problem that doesn't exist, especially when that fix will actually make things worse?
John, after extensive discussion in theother thread, one could get the feeling that most of it went over your head...
A basket/motor is a very different beast than a wall panel. It is not inherently well damped like a plywood panel... and a small resonance has a much more profound affect on the sound then a small panel resonance since it is directly connected to the speaker (actually it is part of the speaker)...
... and did you also miss the part where you got 2 fixes for the price of 1 -- just as important, in some cases more important, is the shaping of the basket exit. Even if you have a basket that doesn't need any damping, it can benefit from careful shaping.
dave
Old 12th June 2007, 12:33 AM   #405
MJL21193's Avatar
Yes, right over my head.
I found it interesting that you would advocate basket damping but not panel damping. I already agreed that basket damping has some value, and as for the shaping to streamline airflow? Could have some merit.
You have finally put into clear words how it is that the system of speaker building that you have adopted works. Sounds good to hear it explained like that.
I (as usual) have a problem though. We have been refering to resonance a lot, and it seems to be a kind of benchmark for noise. What about in frequency spectrum above it, and below it? You yourself said it's the noise 40dB down that will ruin the way a speaker sounds.
I know that there >might< not be enough enery to excite the panels resonant frequency, but it will vibrate none-the-less. This I know from my own speakers built from BB plywood with no damping.
Using your own analogy, the container doesn't overflow, but we can still hear the water running.
Old 12th June 2007, 12:47 AM   #406
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Dave;
linoleum glued to a plywood converts mechanical energy of vibrating walls into a heat. It is not about changing a frequency though it is very heavy, it is about reducing amplitude of vibrations. Also, wavelengths on surfaces of such different materials are very different, so...
The Devil is not so terrible as his math model is!
Old 12th June 2007, 02:06 AM   #407
frugal-phile(tm)
planet10's Avatar
If the panels aren't resonanting, then the panels aren't vibrating (that is by definition) -- the energy being pumped into them is being damped...
dave
Old 12th June 2007, 02:08 AM   #408
frugal-phile(tm)
planet10's Avatar
Sure seemed to me like i was repeating myself... i'll grab that snippet for future reference...
dave
Old 12th June 2007, 02:44 AM   #409
MJL21193's Avatar
dave
Sorry Dave, but I finally understood that you believe noise only happens at resonance.
Old 12th June 2007, 06:41 AM   #410
frugal-phile(tm)
planet10's Avatar
f the panels are not properly damped, they will vibrate below the resonant frequency.
If the panel is vibrating it is resonating. Plywood is inherently well damped, and it is stiff. If resonances aren't excited the panels aren't vibrating.
I use finese to keep my boxes from being a sound source, not brute force.
dave
Discussion on what materials to build speakers out ofHide this!Advertise here!
Cone Materials Discussion J.R.Freeman Multi-Way 46 11th May 2009 02:22 AM
Other ESL build with simple materials available from local grocery stores Audio_idiot Planars & Exotics 69 7th September 2006 06:52 PM
Copyright ©1999-2017 diyAudio
