| Construction Tips Construction techniques and tips |
#351 |
You're welcome! Hope it performs as well as mine have.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#352 | |
Acrylic Lacquer paint was the common auto paint used by GM in the 70s and 80s until more advanced formulations and the VOC laws came into effect. Dupont was the main supplier but not in rattle cans. Fender used this Dupont Automotive paint to paint their electric guitars - the colors, except for a few, were automotive colors: Vintage Guitars Info - Fender custom color finishes on vintage Fender guitars Last I checked, and you have to be careful because the formulations are changing - do your research, Duplicolor and Plasticoat are spray acrylic lacquer auto touch up paints. One of our auto parts stores can usually get any auto color in the Plasticoat large cans within 24 hrs. A good automotive paint supply store should be able to put any auto color paint into a rattle can for you but they are not inexpensive. As soon as you do a big job it becomes much more cost effective to buy a spray gun and most suggest this anyway for the many advantages. I'm interested in spraying very small jobs with rattle cans and I think it would be good to start a new thread on it since I don't think it was the original intent of this thread. Last edited by PB2; 8th December 2011 at 09:17 PM. |
#353 |
"I'm interested in spraying very small jobs with rattle cans and I think it would be good to start a new thread on it since I don't think it was the original intent of this thread."
If it is for a high gloss finish it's applicable to this conversation. Not everyone has access to or wants to use spray guns. I love the HVLP and conversion guns I have. Fantastic finishes. Not a speaker but still gloss finish. This was NOT polished out. Straight off the gun finish. Target EM6000 over General Finishes Espresso (my recipe) All waterbase for obvious reasons.
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. Last edited by Renron; 9th December 2011 at 07:52 PM. Reason: Added photo |
#354 | ||
This is what i bought now Rustoleum Lacquer Spray in Chinese Red and it is Acrylic Lacquer actually. I haven't tried it yet but it looks promising. A little update, in my previous pictures of the lamp I have had a crack develop in the wood due to humidity i guess and you can see a line so i got pissed off and decided to scrap that enclosure and build another one out of MDF with lock miter joints ![]() Your comment was very helpful! Thank you, it confirmed that Acrylic Lacquer Hi-Gloss is the way to go I guess. I am actually almost ready to paint the new lamp. Hopefully it goes good and i get to use the same procedure for the speakers i am building. Btw I am going to use a Foam Roller with B-I-N® SHELLAC-BASE PRIMER i read it is really good somewhere, any advice? I really want to roll it on cuz i dont want to deal with the spray untill the color.... even than i kind of want to roll the color on too but idk about that :/ Quote:
#355 |
Did it Himself
Rolling on the primer should be ok as you can sand it back a lot. Same with the top coat, you can roll it on, but it just takes more effort sanding back to the nice finish that if you sprayed it. And you use more paint obviously.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#356 | |
![]() GM
#357 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Renron crib looks awesome. I to almost always use waterborne spray. I like the general finish much more then the target coating. Seems to lay out nicer, less problems with fish eyes, and holds on better when sprayed on a vertical surface.
http://www.evancotler.com |
#358 |
Excellent site for picking colors:
Blue Corvettes at PaintRef.com http://paintref.com/paintref/index.shtml Last edited by PB2; 12th December 2011 at 02:03 AM. |
#359 |
EvanC,
I've yet to use General finishes top coat, but on the next project I will get an opportunity. I really like the fact that Target EM6000 burns in between coats. No witness lines if you sand through different layers. Don't even need to sand between coats unless you've got a run or a bug. I've never had a problem with fish eyes either, but then I always use de-waxed shellac between the stain and top coat. I have 2 guns too, one for oil and one for WB. What GF product do you like to spray? I'm building a bookcase and mantle next. Suggestions would be great. Sorry, a little off tangent but still on topic. Obtaining a quality finish. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#360 |
I like the pre cat 181. I get it from homestead finishing
General Finishes I still use a bit of solvent based pre cat ML Campbell sprays better and dries faster then the waterborne, but it stinks.... Shellac is my choice for smaller / nicer projects. works like lacquer but is not as toxic. The ultra pale is my choice for light woods and as a base for all other finishes. Shellac
| Mod Podge and Micro Gloss | BHD | Full Range | 19 | 13th November 2007 01:25 PM |
| Piano gloss tips | paulspencer | Multi-Way | 4 | 2nd January 2007 08:37 AM |
| Discussion about gloss paint finish technique | Vikash | Multi-Way | 40 | 7th July 2006 11:41 AM |
| Problems with high gloss finish | jarros | Multi-Way | 17 | 16th October 2005 03:15 PM |
| Paper Cone Gloss | Mjr7531 | Multi-Way | 5 | 24th February 2005 04:57 PM |
