| Construction Tips Construction techniques and tips |
| Thread Tools | Search this Thread |
#221 | |
#222 | |
I think they look great! Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#223 |
Thanks ^^
#224 |
#225 |
Man, that's fantastic! Very nice, thanks for the HQ picture. Nice and flat reflection. Shows how much hard work you put into your speakers. Congratulations. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 |
#226 |
Very nicely done!
#227 |
Thanks, needless to say I'm so happy with the results. Now that I've done it once I have some ideas for refining the process I used a little. I can't wait to give it a go on the next set of speakers.
#228 |
I'm just wondering If after I applied a 2 part primer and 3 coats of black paint And flattened the surface, Can I use a paint roller to apply the top clear coat? , Then flatten and polish ? HAs anyone tried this?
#229 |
I would only do this if I LOVED sanding. even the best rollers don't come close to as smooth as spraying.
once you get it flat, if you spray evenly it should stay fairly flat and be easier to rub out. |
#230 |
Who doesn't!
I agree, even with an HVLP you need a reasonable amount of sanding. With a roller you'd be shooting yourself in the foot to get out of walking a mile.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| zxgravediggerxz |
| Mod Podge and Micro Gloss | BHD | Full Range | 19 | 13th November 2007 02:25 PM |
| Piano gloss tips | paulspencer | Multi-Way | 4 | 2nd January 2007 09:37 AM |
| Discussion about gloss paint finish technique | Vikash | Multi-Way | 40 | 7th July 2006 12:41 PM |
| Problems with high gloss finish | jarros | Multi-Way | 17 | 16th October 2005 04:15 PM |
| Paper Cone Gloss | Mjr7531 | Multi-Way | 5 | 24th February 2005 05:57 PM |
| Page generated in 0.11403 seconds (76.31% PHP - 23.69% MySQL) with 11 queries |
