Construction Tips Construction techniques and tips
A 'how to' for High Gloss Finishing
Old 9th January 2018, 11:09 PM   #491
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
option 1 (Acryl Classic Top Coat 2K Klarlack HS 2:1) says it polishes easily. Flattening and polishing the finish once it cures is a big part of a high gloss finish.
http://www.evancotler.com
Old 9th January 2018, 11:14 PM   #492
jplesset is offline jplesset  United States
I have sprayed both regular lacquer and automotive lacquer. Both can create a very high-gloss result. The automotive finishes are MUCH more expensive. I just purchased a gallon of clear high-gloss lacquer for spraying cabinets. $50. Two years ago, I bought 1 quart of automotive gloss catalyzed lacquer, for $200.
The automotive product is "better" in that it is more water resistant, more likely to last out doors. The finished product looks great in both cases.
Old 10th January 2018, 09:36 AM   #493
diysub is offline diysub
Thank you all for helping me.
Each clear coat I mentioned costs almost the same 60$/gallon. Maybe I will choose the automotive one.
I would like to make the gloss finish on a DIY subwoofer.
Unfortunately I cannot buy a sealer rattle can in my country which was highly recommended. I am wondering if I make a lot of layers of the primer, if I can have the same result. I know this is important because of the absorption of the lacquer.
Have a nice day!
Old 24th January 2018, 09:51 PM   #494
I have read that the isocyanates are dangerous so I am trying to avoid the clear coats that contain it. I have found a great alternative.
Does this contain any dangerous chemicals like isocyanates?
This pigmented lacquer uses modified alkyd resin, do you have any experince with it?
Thanks in advance.
A 'how to' for High Gloss FinishingHide this!Advertise here!
Mod Podge and Micro Gloss BHD Full Range 19 13th November 2007 01:25 PM
Piano gloss tips paulspencer Multi-Way 4 2nd January 2007 08:37 AM
Discussion about gloss paint finish technique Vikash Multi-Way 40 7th July 2006 11:41 AM
Problems with high gloss finish jarros Multi-Way 17 16th October 2005 03:15 PM
Paper Cone Gloss Mjr7531 Multi-Way 5 24th February 2005 04:57 PM
