Construction Tips Construction techniques and tips
How do you punch out your chassis holes?
Old 30th October 2005, 05:50 AM   #11
Bill*B is offline Bill*B  United States
Greenlee "730" chassis punches are great for tube sockets. They are expensive if purchased new, but are often offered at reasonable prices on eBay. Quick and precise.
Old 30th October 2005, 09:38 AM   #12
On Hiatus
SY's Avatar
I have Greenlee punches for octal, 9 pin, and 7 pin socket sizes. I got them for my 13th birthday, and after nearly 40 years and having built a few hundred tube projects, they still work perfectly.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th October 2005, 10:03 AM   #13
Geek is offline Geek
Geek's Avatar
Until I can afford good punches, I use a 28TPI blade on my scrollsaw and lots of oil. keep it around 900 SPM or less for aluminum and other soft metals. Steel, forget it!
Regular twist drill bits (titanium with the most used ones being cobalt) for smaller holes (1/2" and less).
Old 31st October 2005, 02:00 AM   #14
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
I use a series of three different unibits to go up tp 1.25" , then Greenlee punches, or a verticle mill if the hole is rectangular.
Mark
Old 31st October 2005, 02:38 AM   #15
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I broke the draw-bolt on my 7-pin Greenlee punch and have been looking for a replacement -- any suggestions.
Old 31st October 2005, 03:44 AM   #16
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Whenever using all these ideas that require a spinning blade on sheet metal be very sure the metal is anchored well. If not when the tool jams, the metal becomes a rotary saw on your fingers!!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 31st October 2005, 09:12 AM   #17
On Hiatus
SY's Avatar
Maybe McMaster-Carr?
Old 31st October 2005, 03:40 PM   #18
amperex is offline amperex  United States
Default socket & transformer holes
For round holes I use Greenlee punches. Makes for an ultra clean hole & various sizes are perfect for most tube sockets.
As for square holes, I use a chassis 'nibbler' tool. It snaps out a small 1/8" x 1/4" piece at a time. Tedious, but does perform. After I am finished with the nibbler square hole, I use a flat file to smooth out each side of the square hole.
A nibbler tool can not cut steel easily that is thicker than about 20 guage. Aluminum is easy & any aluminum Hammond chassis is not a problem. Real square punches exist, but are terribly expensive.
If I was to mass produce tube gear, I would use a custom die & 30-50 ton press.
Old 31st October 2005, 03:50 PM   #19
jackinnj's Avatar
time for some serious CNC discussion here -- I have a Grizzly mini-mill which the "young men" of the family purchased for me 2 Christmas' ago -- one of their friends, a CMU grad has adapted a bigger Grizly with XYZ stepper motors --
so you don't need a 30 ton punch press anymore -- but you will need to figure out how to translate your cad drawings.
Old 31st October 2005, 10:15 PM   #20
Geek's Avatar
... but you will need to figure out how to translate your cad drawings.
A handbook on Perl/Python/Tcl can be your best friend in such a case maybe
How do you punch out your chassis holes?Hide this!Advertise here!
Chassis/Enclosure that has all the holes on the back precut??? nick_g_evans Chip Amps 3 6th December 2007 06:13 AM
Silly Chassis Punch Question... soulmerchant Tubes / Valves 15 22nd November 2006 08:01 PM
What do you guys use to drill holes on chassis?? jamesjung21 Tubes / Valves 48 15th May 2005 09:21 AM
Chassis constrution and tapping holes s_c_leach Solid State 7 30th June 2004 11:17 AM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 07:56 PM
Copyright ©1999-2017 diyAudio
