How do you punch out your chassis holes? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 13th October 2012, 02:31 PM   #31
I drill a pilot hole then use a boring head on a milling machine. Don't have any punches, so have to go with what you have.
Old 13th October 2012, 10:00 PM   #32
roline is offline roline  United States
roline's Avatar
I found a source that has a waterjet that can cut 1/2 steel, they can use a DXF file from Autocad, so if it were to be cost effective, that would be another way.
Another source quoted around $120 for 2, laser cutting. I don't know how much slag would build in the curf.
I'm kinda twisted, those are triple triode compactrons driving 6LB6 outputs.. 12 pinners.
SO many tubes, SO little time!!!
Old 13th October 2012, 10:28 PM   #33
balerit is offline balerit  South Africa
balerit's Avatar
Laser cutting is clean, we have aircraft parts laser cut, saves time and has a real clean cut.
Mac
The Book Worm - DIY Audio Ebooks and Manuals - Speakers, Moscode Amplifiers, Electronics, Map Reading, Free Capacitor Intro.
Old 14th October 2012, 03:31 AM   #34
I used a $13 stepped drill from Amazon for my first project. It worked OK. More function that finesse. If this addiction really takes hold, I'll get some punches.
Old 14th October 2012, 01:52 PM   #35
Roline....before you fork out that much money check and see if there is someplace that does EDM in your area. Works great on thicker material and should be substantially cheaper. Off topic, but i had 2 magazine wells cut on rifle receivers i was making. Accurate cuts and smooth as the proverbial baby's bottom. regards, J.D.
Old 14th October 2012, 03:52 PM   #36
There was a discussion on this before. http://www.diyaudio.com/forums/tubes...punch-set.html
For holes larger than 1/4 inch, I use Greenlee punch set I found used on ebay. For small holes, I use deep throat metal hand punch.
The real one is $250 but I bought an imitation from ebay for $55. It's good enough for one or two projects but beyond that, it will wear out (because it's a cheap imitation). But it's still better than having to "set" the hole with set punch and possibly bend the plate and then trying to hold a drill bit in place for small holes. The hand punch produces more accurate location.
Chassis/Enclosure that has all the holes on the back precut??? nick_g_evans Chip Amps 3 6th December 2007 05:13 AM
Silly Chassis Punch Question... soulmerchant Tubes / Valves 15 22nd November 2006 07:01 PM
What do you guys use to drill holes on chassis?? jamesjung21 Tubes / Valves 48 15th May 2005 08:21 AM
Chassis constrution and tapping holes s_c_leach Solid State 7 30th June 2004 10:17 AM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 06:56 PM
Copyright 1999-2017 diyAudio
