How do you punch out your chassis holes? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th November 2005, 09:12 PM   #21
kevinkr's Avatar
Titanium or carbide drill bits up to 1/2" or so. Greenlee chassis punches or equivalent for holes up to 1 1/2" and a nibbling tool for odd sized or shaped holes.
Most of my chassis are aluminum from bud, hammond, or SMB. Easily worked which is why I mention them. Sometimes (rarely now) I make them from scratch if I have access to a good bending brake.
Steel is really hard on drill bits and punches.
While drilling use lubricants, remove swarf frequently. Lubricate draw bolt on punches, or better still get one with bearing if possible.
Be safe! (Wear safety glasses!)
Kevin
Old 4th November 2005, 10:11 PM   #22
jackinnj's Avatar
Safety Glasses
We have dozens of sets around here -- a small shard of metal can blind.
Old 5th November 2005, 06:12 AM   #23
wrenchone's Avatar
I use a conical step drill to make holes, then open them out if needed with a nibbler. The holes a lot of the time need a bit of deburring - I just use a drill somewhat bigger than the hole to clean the crud away.
Old 9th November 2005, 01:34 PM   #24
garbage is offline garbage  Singapore
garbage's Avatar
Talking plain hard work
Originally posted by elementx
how do you? jigsaw? tiedious drilling?
i'm refering to socket holes, transformer holes...
first mark out 3mm or so from the perimeter, use a dot punch to mark reasonable distances for a 4mm drill bit. the idea is to end up with holes very near to each other. using a bench press, drill the required holes. use a hacksaw blade to saw thru all the holes, causing the inside piece of metal to fall out. then finish off with a metal file.
i did the below on a 5mm piece of aluminium. the cutout was for a led display for my preamp.
for thinner metals, you might want to check this tutorial.
cheers
garbage
Old 13th October 2012, 07:51 AM   #25
bullpeters's Avatar
80 bucks on ebay in Australia gets you a 10 ton press that knocks holes in 3mm mild steel and no burrs!!
Old 13th October 2012, 09:20 AM   #26
multi is offline multi  Australia
There are lots of Chinese made Hydraulic chassis punches on Ebay. about $A150.00
i have found they are very good, not as good as the Japanese hydraulic chassis punches, but they cost $1500.
Phil
Old 13th October 2012, 12:24 PM   #27
balerit is offline balerit  South Africa
balerit's Avatar
http://www.parts-recycling.com/Comme...oles-photo.jpg
Old 13th October 2012, 12:39 PM   #28
roline is offline roline  United States
roline's Avatar
Greelee hole punches for tubes and stepped drill bits for up to 3/4 inch. The Greelee punch is just a little too small and holes get a final sanding for the sockets to just pop through. I leave a little clearance for thermal expansion when the tubes heat up.
For the tube vent slots I use a jig to hold the axle for the center of the tube in a mill and use a 3/16" 4 flute bit and rotate the top to get the arc needed. Lift the bit, rotate to the new spot, drop the bit and rotate the top plate again.
SO many tubes, SO little time!!!
Old 13th October 2012, 12:47 PM   #29
On Hiatus
SY's Avatar
Compactron driver to sweep tube outputs? I like your style.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th October 2012, 02:16 PM   #30
I've used punches, verticle mill, and water jet cutting. Lately, I've been toying around with the idea of using carefully formed charges of C-10.
Mark
Chassis/Enclosure that has all the holes on the back precut??? nick_g_evans Chip Amps 3 6th December 2007 05:13 AM
Silly Chassis Punch Question... soulmerchant Tubes / Valves 15 22nd November 2006 07:01 PM
What do you guys use to drill holes on chassis?? jamesjung21 Tubes / Valves 48 15th May 2005 08:21 AM
Chassis constrution and tapping holes s_c_leach Solid State 7 30th June 2004 10:17 AM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 06:56 PM
Copyright 1999-2017 diyAudio
