Construction Tips Construction techniques and tips
Toner transfer with a twist -- anyone tried this?
Old 31st August 2005, 07:24 PM   #11
AudioWizard is offline AudioWizard  France
Ok... well, all in all, I think that toner transfer isn't so bad. ;-)
I highly recommend Pulsar products (TTS...). Very easy to work with. The thing is to find the right amount of temperature and pressure; I was used to glossy photo paper, and TTS is much thinner, so you have to set your iron to a much lower temp and apply it for only a few seconds (whereas I ironed for like 2 minutes with photo paper). If temperature is too high, the finer toner tracks will get kind of fuzzy.
I don't think that it would be worth the trouble to hack a laser printer and all, unless you made boards in high quantity - but then again, if you did that, you would probably not make them yourself...
On the idea of directly printing on copper - if that's a problem with laser printers because of electrostatic diffusion, I guess we could use an inkjet printer instead, and print on copper sheets. Then we would need resistant ink, but I think I remember that some company actually makes inkjet inks for that purpose... or maybe it was some hack to put some special ink in regular, used cartridges...
Old 31st August 2005, 08:48 PM   #12
rif is offline rif  United States
Neither a cowbow nor dog owner
rif's Avatar
Originally posted by jackinnj
there aren't many things worse in a workshop than carbon black -- it smudges everything AND conducts electricity.
you can use a plotter to apply waterproof ink directly from pen to copper -- here's the problem -- most of the plotters are programmed in HP/GL (Hewlett Packard Graphics Language) -- you have to get the gerber file and then manipulate it -- great if you remember DOS and how to use a text editor.
i have done this with small boards -- only a few square inches -- it works. with larger boards the inertia of the PCB is such that it is difficult to maintain registration -- at least on the plotter which I used.
Ah -- but how about hacking an inkjet and turning it into something else? A normal inkjet's "axes" are left/right -- the printer head moves back and forth, and feeding the paper around a roller. What if we got rid of the roller, and rigged something to step the PCB or the print head? It's not a plotter since it still only moves one of the axes in one direction -- just changing the mechanics of the axis. It has the benefit of using modern, standard unmodified drivers
Old 1st September 2005, 12:39 PM   #13
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Default plotting pcb's
I used a plotter for plotting pcb's. I even made a web page for it some time ago here
Disadvantages are: sometimes the etched pcb came out with jagged edges, when covering larger area's the ink would sometimes etch away a little but that was probably due to the etch-resist pen i used.
All in all a not very satisfactory system. I switched to laser-toner-transfer but that gave more problems due to paper choice. And the jagged edges remained.
The accompanying foto shows the faults in larger ink-area's (pcb backlit with a lamp)
Si fractum non sit, noli id reficere!
Old 1st September 2005, 03:24 PM   #14
matjans, it's not that bad, really. Probably unacceptable if you sold your boards, but for amateur work, it's ok. Won't make a lot of difference in the final circuit. ;-)
Old 1st September 2005, 03:40 PM   #15
rif's Avatar
Default Re: plotting pcb's
matjans -- that's a really nice website -- did you create it yourself?
Old 2nd September 2005, 10:22 AM   #16
matjans's Avatar
yep, i made it myself.
Audiowizard: all the light spots in the black (copper) bands are etched away right down to the epoxy, around those spots the copper is pretty thin so I discarded them.
On using inkjet printers for "printing" pcbs.: there are inkjet cartridges that contain a sort of wax-based ink. They're used for those iron-on t-shirt prints. The ink dries pretty fast. Maye that would work?
Old 2nd September 2005, 11:07 AM   #17
cocolino is offline cocolino  Germany
cocolino's Avatar
A quality film is the key in successfully and easily etching good PCBs at home. Once You have a good film the rest is a breeze.
I think I messed with everything what concerns making DIY films for PCB exposure (I started making films by gluing those black tape stripes on clear foil ).
After all I came to the conclusion that ALL of the DIY methods are unsatisfying for high qualtiy results and there is no way around getting films made on a professional film exposure machine that usually works with PostScript files (I don`t know what is the correct notation in English for that kind of machine. In German it`s called "Satzbelichtungsmaschine").
Anyway, ask at Your local print shop, they probably have such a thing or at least they might know where to go. Prices are reasonable, I pay around 1 Euro per 10x10cm highest quality film - black areas absolutely leakproof against light, finest resolution (usually 2400dpi) with razorsharp outlines.
I think that is really worth it.
Christoph
STEAL the BEST - INVENT the REST
Old 7th September 2005, 12:10 AM   #18
mercator is offline mercator  Canada
mercator's Avatar
I think it is called photomechanical transfer (PMT) in english. Makes excellent quality linework for a low cost.
/Dave
Experience is what you get when you don't get what you want.
Old 8th January 2018, 06:09 PM   #19
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
I know some roland printers also are capable of cutting film used for heat transfer used in t shirt printing that replace the print head with a cutter and film...
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Toner transfer with a twist -- anyone tried this?Hide this!Advertise here!
PCB: toner transfer using acetone? Limhes Parts 4 22nd February 2008 07:55 PM
I tried toner transfer today... gmikol Parts 11 13th December 2006 06:00 AM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
toner transfer method(my mistakes) rs1026 Everything Else 3 13th October 2004 01:37 AM
