Construction Tips Construction techniques and tips
Making PCB without a computer
Old 16th August 2018, 12:21 PM   #41
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Beware of the stock footprints in any PCB program. They are often close to, or equal to the manufacturers recommendations which are optimized for machine insertion and wave soldering for leaded parts and pick and place with solder paste for SMD assembly. Neither of these are best for hand soldering by less than perfect DIY builders (rookies or old shaky hands like mine).
For many parts especially TO92's, but even for leaded resistors, I spread the leads and use larger pads.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th August 2018, 12:36 PM   #42
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by Tubelab_com View Post
Beware of the stock footprints in any PCB program...
...For many parts especially TO92's, but even for leaded resistors, I spread the leads and use larger pads.
In total agreement here.
That's why I like EspressPCB, I design all my own footprints with larger pads, typically 80 thou with 35 thou drill.
The only let down is that it's limited to round or square pads and no option for oval DIL style pads.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 16th August 2018, 01:46 PM   #43
campsquire is offline campsquire  United States
General rule I have:
If you want to make more than one of some PCB design, go computer, otherwise anything goes.
Although I've never done this, I've wanted to try a three dimension sculpture using discrete through hole components, no wire, just interconnecting leads. Pot it in clear liquid resin. The end result would look chaotic which most people assume is what electronics is about anyway.
Old 16th August 2018, 04:35 PM   #44
edbarx is offline edbarx  Malta
The advantage of a well planned and thought PCB layout using a computer should be that of neatness and ease of identifying the various circuit elements. I am after that, and I also consider neatness as a plus. One simply cannot demonstrate the interior of an DIY amplifier if this is chaotically built. I want something worthy of admiration, and that, I am afraid requires great patience and perseverance.
Making PCB without a computerHide this!Advertise here!
Making a PA system using cheap computer speakers webmiester PA Systems 8 9th July 2017 01:49 AM
Boat making techniques in Speaker Cabinet making.... sansterre Construction Tips 14 28th May 2013 02:03 PM
BOX in the making tinitus Tubes / Valves 9 21st October 2012 02:15 PM
Making a two way Zardoz89 Multi-Way 6 23rd February 2009 12:40 AM
Making a computer sub amp audiobahnkid592 Chip Amps 2 23rd March 2007 06:25 AM
