Construction Tips Construction techniques and tips
Amplifier casing design
View Poll Results: Which design do you like the most?
Design 1 (top left) 13 38.24%
Design 2 (top right) 6 17.65%
Design 3 (bottom left) 2 5.88%
Design 4 (bottom right) 13 38.24%
Voters: 34. You may not vote on this poll
Old 31st May 2018, 11:54 AM   #11
Bremfighter is offline Bremfighter  Netherlands
Originally Posted by Mooly View Post
Bremfighter. Please read the rules concerning starting multiple threads for the same topic.
Your other two identical threads have been deleted.
Allright, the problem was that I didn't knew in which forum my topic belonged, since my first thread did not get any response I thought I had put it in the wrong forum.
Old 31st May 2018, 03:34 PM   #12
DF96 is offline DF96  England
Originally Posted by Dave Zan
I believe in 'form follows function'
Yes. The layout of controls will be determined partly by the circuit and partly by ergonomics, and that then leads on to any cosmetic features. For example, the volume and source selector knobs are often larger than other controls. Starting with cosmetics is starting from the wrong end of the problem.
Most of us no longer buy amplifiers, so we are not necessarily the best people to ask.
Old 1st June 2018, 08:53 AM   #13
Yes you're right, you should always start out with the internal functios and to solve the requirements that you set when designing a product. However, the pcb is already made and a list of requirements (for example the different types of input and the controls) are already written down. But the overall shape did not have any influence on my requirements so the shape is (almost) completely free. That's why I only showed the overall shape. No matter which one I choose, the requirement will get into the product
Old 1st June 2018, 06:25 PM   #14
russc is offline russc  England
No 1 because I like clean unfussy designs.
The asymmetry appeals also.
If required, there is room for a series of buttons under the display.
Amplifier casing designHide this!Advertise here!
Before casing: what and why? Malefoda Class D 0 13th May 2013 08:40 PM
How big casing for loudspeakers? Decriptor Multi-Way 6 26th April 2009 05:16 PM
Designer casing Gabster Group Buys 4 8th January 2009 11:13 AM
casing for cd pro 2 Pocoyo Everything Else 1 5th March 2007 03:17 PM
Casing dimensions Mlaen Solid State 1 20th February 2005 06:32 PM
Resources saved on this page: MySQL 13.64%
