Construction Tips Construction techniques and tips
Need help with a Random Audio Switcher
Old 18th April 2018, 09:33 AM   #1
peckersonth is offline peckersonth  Germany
Default Need help with a Random Audio Switcher
Hello diyAudio Community,
i have a problem with a circuit maybe you can help me with.
I need for an exhibition an audio switch which switches 9 inputs to 1 output at a random rate. Only 1 input at the time is active.
The input is stereo via 3.5mm jack so is the output.
The problem i have is that i have a really bad crosstalk on the channels
I use an ADG409 for the switching an atmega328 as a controller
Vdd is 5v Vss is tied to GND
What can I do to remove the crosstalk / noise ?
Old 18th April 2018, 10:45 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Schematic would be useful.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 18th April 2018, 05:22 PM   #3
epicyclic is offline epicyclic  United Kingdom
What are the signal levels of the inputs .
Old 18th April 2018, 05:27 PM   #4
PRR is offline PRR  United States
PRR's Avatar
Your inputs swing above and below common.
The switch chip is powered with +5V and common, and does not do a right thing when inputs go outside this range.
I am thinking that all negative swings on all inputs are breaking-over inside the switch chip.
You could R-C couple all inputs and outputs to a mid-way voltage reference.
You could re-arrange the whole power scheme centered +/- around common; this does complicate the logic interfacing.
Frankly, since the board is built and you have 12V, _I_ would get 9 electromechanical relays to do the audio, coils driven by DC power through the ADG switches (backward). It is klunky but gets the project finished quick.
Old 19th April 2018, 06:33 PM   #5
Thank you PRR I will re-arrange the power scheme and will try a +15 and -15 V supply. And I will add 10k resistors between audio and audio gnd. i will post the new Schematic soon.
Old 20th April 2018, 06:27 AM   #6
i got a new Semantic can anyone take a look ? And give me advice ?
Greetings Tim
Need help with a Random Audio SwitcherHide this!Advertise here!
FS: Prism dScope III and dS-NET-I/O Switcher audio analyzers axismundi Swap Meet 10 14th April 2017 11:42 AM
Relay audio switcher raidfibre Analog Line Level 2 6th September 2012 12:27 PM
Analog audio switcher Pleh Analog Line Level 2 5th September 2012 03:30 PM
Audio Measurements with filtered random noise misureaudio Equipment & Tools 1 11th January 2010 04:18 PM
Silent switching for XLR audio switcher Smeltis Solid State 0 31st March 2006 01:02 AM
