Construction Tips Construction techniques and tips
Paper Horn constuction
Old 25th February 2018, 07:36 PM   #11
Pano is offline Pano  United States
Pano's Avatar
I like the idea of wax or shellac and the quick dry. I made a pair of papier mâché horns from 100% cotton heavy art paper and wall-paper glue. Took forever for each layer to dry. Sounded amazingly good, tho.
Take the Speaker Voltage Test!
Old 25th February 2018, 08:55 PM   #12
silverprout is offline silverprout  France
silverprout's Avatar
Originally Posted by PRR View Post
How many sides? An awful lot of the old horns have 11 sides. There may have been a published pattern for this; or it may have been a standard at some company. Mystic Numerics will suggest other numbers for Divine Properties. Being atheist, I will note that our circular approximation gets poor at 4 sides (however math it as a square and the same approach is perfect). At silverprout's 7 sides, I'd call the pi math perfect for any practical purpose (you *will* scale your horn a bit bigger than your actual passband).
11 sides seems to be a good approximation IMHO, grandaddy was right.
The unpressed version of the "champagne jeroboam hom generator prototype" is 4mm thickness, dry completely within 8 hours and have enough rigidity to avoid any doping.
One polymer textile layer really accelerate the drying process, i must thanks the womens feet.
Things I Should Have Learned In School (But Probably Didn't)
Old 26th February 2018, 11:28 AM   #13
Pano's Avatar
That's pretty.
BTW, thanks for the horn plot with and without the paraffin. It has quite an effect at the low end.
Old 26th February 2018, 05:25 PM   #14
DonVK is online now DonVK  Canada
DonVK's Avatar
How are the CD's attached. Is there a reusable threaded piece or flange added ?
Old 26th February 2018, 06:14 PM   #15
Flange added (laser cut plywood) pieces are entering the mass production phase, i will produce a lot of horns !
The first one will be the HOM generator that gives a huge resonance of 10 dB at 1000 Hz
Old 26th February 2018, 06:39 PM   #16
DonVK's Avatar
I was thinking of a pipe fitting for a screw on CD. Both could be reused on the next horn. Since the horns are paper they could be recycled as well.
I do enjoy the pleasing sound of a resonant 1Khz tone. Maybe I could make a paper "ear trumpet" so that I'll be able to hear it as well.
Old 26th February 2018, 06:59 PM   #17
The threading process is too complex and the junction to the horn will be severely degraded on good designs (if it happens )
Old 26th February 2018, 07:20 PM   #18
DonVK's Avatar
I'll be very interested in how you attach that flange. I'm looking forward to more pics and results.
Old 26th February 2018, 11:14 PM   #19
mkane77g is offline mkane77g  United States
Always Learning
way more complicated shape than I can duplicate with wood. There fantastic looking and I wish I had a way to duplicate them. No CAD software here or a printer large enough.
Old 27th February 2018, 08:28 PM   #20
I know that you are impatient to see my flange attach... so here is my last creation :
The SHREDDER !
ouch....
Paper Horn constuctionHide this!Advertise here!
Started building a 160 hz paper horn for a 6" fullrange bqc Full Range 35 18th June 2013 04:48 AM
Mad as a hatter - 1200/60 Hz paper horn speaker woodelf Multi-Way 1 16th February 2012 02:14 PM
diy horn in paper for singing... then_dude Everything Else 2 15th June 2011 03:34 PM
Constuction Help - Booming powered speaker kurtbauer Multi-Way 18 13th July 2007 09:43 PM
