Construction Tips Construction techniques and tips
Rounding veneered mdf, possibly?
Old 26th January 2018, 06:14 PM   #1
mart34 is offline mart34  England
Default Rounding veneered mdf, possibly?
Has anyone successfully used a router with a roundover bit, to round veneered mdf?
I like the idea of building the box out of veneered mdf sheet, then finishing off the edges with a router.
I'm concerned the veneer might catch and rip off, which won't happen when doing a straight cut with the right quality tools.
If not roundover, how about a 45 bit?
Many thanks
Old 26th January 2018, 06:30 PM   #2
DPH is online now DPH  United States
Just to clarify: you have *already* veneered the panels and then want to put roundovers onto the corners? That simply wont work, and you'd need to look at using solid wood corners that you join to the veneered panels.
If you mean making an MDF box with roundovers on the corners *then* applying veneer -- yes, it's doable. The corners are a pain for sure, so if you can put a generous roundover (0.75"/19mm or greater), then the curvature is pretty manageable. I've done 1/2" and it's not exactly fun.
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Old 26th January 2018, 06:56 PM   #3
Thanks for reply. Considered building an mdf box (whether straight edged or rounded edge) then veneering but I'm not confident I'll get the finish. I'm a perfectionist and would hate to build the box then ruin the veneering.
I actually meant pre veneered mdf panels. Link below
Veneered MDF Black Walnut Sheeting Cut To Size
Then using the router to round the edges. I'd be content staining the bare rounded mdf edges. I think this is what BKELEC do with their subwoofers, unless they use a wood quadrant on the edges, I'm not sure.
Old 26th January 2018, 07:06 PM   #4
Okay, I see what you mean now. If you can get some scrap, then I'd recommend taking a razor blade and making a score line at the roundover edge to reduce the chance of chip out. I've used a laminate trim bit to clean up the edges (namely on the driver cut outs) without issue.
My gut instinct is to say that the look of MDF edges with walnut veneer will be pretty undesirable, sadly. Any future projects I do with rounded baffles will use solid wood at least in the corners, if not the entire front (with a constrained layer damping to plywood) to avoid veneering the roundover. Flat panels with sharp edges aren't bad to veneer, though, in my experience.
Old 26th January 2018, 07:43 PM   #5
Thanks appreciate your advice. I just really don't trust my veneering skills. So my optons are to -
1. Use the pre-veneered mdf for all sides but then use solid walnut quadrants to mate the edges flush.l (concealing the mdf ends of the sheets)
2. Use pre-veneered mdf then use lengthe of straight solid walnut to almost frame all the edges.
3. Use plywood (router the edges however I want) then finish with a walnut stain, to try and replicate a walnut finish or at least colour.
Thanks again
Old 26th January 2018, 07:48 PM   #6
Yup! Good luck on your project!
P.S. I'd argue that you don't really want to do #1, but rather #2 if you go that way. You don't really need too much solid in order to make this work well, e.g. 1" by 1" in the edges themselves.
Old 26th January 2018, 07:48 PM   #7
lcsaszar is offline lcsaszar  Hungary
I made veneering as on the attachment. 50 mm MDF, this was my first attempt.
Old 26th January 2018, 08:05 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I'm a perfectionist
Then why would you even be considering MDF for a woofer? Not the best material, and you end up with more back-strain. Plywood is not only lighter, but 15mm quality ply will give you better performance then 18mm mdf.
If you veneer before you round-over you will end up with a constrasting edge which if stained in a creative manner can be a nice touch.
Do note that with a woofer a roundover will only be cosmetic (if we ignore what a sharp end can do if you do a face plant against the corner) because the wavelengths are so much longer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2018, 08:13 PM   #9
C'mon Dave, veneer laminated on MDF is pretty common for prefab architectural panels, although walnut-veneer plywood isn't too hard to find.
We're not sure the rest of the construction--and 1/2" mdf with a plywood base would work suitably.
Old 26th January 2018, 08:22 PM   #10
chrisb is offline chrisb
Re #3 above - even with the highest quality veneer faced veneer core plywood, the cross-banded edge plies will take stain very unevenly. I'd suggest something along the lines of Daniel's recommendation, or the example in Laszlo's photo - was that veneer or thin solid?
Also note that if inlaying solid as edge detail to be wary that when sanding flush that the veneer is thin enough to sand through - more so in my experience on MDF core. BTW in the millwork trade, MDF with veneer faces is technically classified by most suppliers as "a plywood"
Daniel - without getting into the argument of MDF vs VC plywood, I'll note that having built a few speakers myself, post veneering a cabinet with edges either beveled in any direction, or rounded over in the long grain direction is easy enough - certainly with the larger radii you suggest - but a radius in the cross grain is tricky, and of course rounded corners are virtually impossible - which is where inlaid solid edging come into play.
This one was a challenge - in the days before I abandoned MDF altogether - the carcass was 1" MDF core dadoed into BB plywood matrix braced frame, with 1/4" veneer plywood, and cherry solid inlaid on all vertical and horizontal edges. Never had a scale in the shop, but they must have been 200lbs a piece - definitely my most time consuming build.
kinda burnt out - taking a break
Rounding veneered mdf, possibly?Hide this!Advertise here!
rounding inside 90's deebeez92 Construction Tips 3 17th April 2013 05:50 PM
Rounding internal angles ziocalepino Full Range 5 25th March 2011 04:13 PM
OB diffraction - rounding both side? Ang Multi-Way 1 11th January 2007 10:44 PM
Veneered MDF suppliers in the UK? Scottmoose Multi-Way 25 21st December 2005 09:41 PM
Front panel edge rounding sianturi Multi-Way 31 10th July 2003 07:17 PM
