Construction Tips Construction techniques and tips
Rounding veneered mdf, possibly?
Old 9th February 2018, 08:47 PM   #51
paul burchell is offline paul burchell  Canada
paul burchell's Avatar
The more freedom to detail edges can also be acheived with a more relaxed stress free joinery. This can be achived by gluing 3/4" square stock around the sub strait bb ply. Level the joints careful not to roll the edges then add a (thicker preferable) veneer . If you are careful to select color and orient grain direction the transition can be fairly seamless.
A simple router jig base can be made for most of the leveling if preferred.
You will still be able to make the baffle a little larger than the box to planed or sand latter.
Paul Burchell Fine Woodworking
Old 13th March 2018, 01:48 AM   #52
Joel Wesseling is offline Joel Wesseling  Canada
Thanks Paul. Have been crazy busy. On Feb 8, I Purchased a new home in Kawartha Lakes region. I will now have a 24 x 46 shop for speaker/wood projects. I will obtain the wood Movement guide from Lee Valley.
Old 13th March 2018, 11:50 PM   #53
Congrats on the new home and big shop. Sounds like you got the whole basement...... For now
Old 16th March 2018, 11:53 AM   #54
Thanks! The shop is the triple car garage - need to figure out best way to heat it.
Old 17th March 2018, 10:18 PM   #55
chrisb is offline chrisb
A pair of 200W Passlab class A amps?
like my mind, this space intentionally blank
Rounding veneered mdf, possibly?Hide this!Advertise here!
rounding inside 90's deebeez92 Construction Tips 3 17th April 2013 04:50 PM
Rounding internal angles ziocalepino Full Range 5 25th March 2011 03:13 PM
OB diffraction - rounding both side? Ang Multi-Way 1 11th January 2007 09:44 PM
Veneered MDF suppliers in the UK? Scottmoose Multi-Way 25 21st December 2005 08:41 PM
Front panel edge rounding sianturi Multi-Way 31 10th July 2003 06:17 PM
