Construction Tips Construction techniques and tips
IKEA Blanda Bamboo Bowl Speakers
Old 30th January 2018, 06:48 PM   #11
dtaylo3 is offline dtaylo3  United States
What is the product # and name of the Ikea bowl that you use?
Old 30th January 2018, 06:48 PM   #12
Ooops. I see it is the Blanda.
Old 30th January 2018, 07:54 PM   #13
repycte is offline repycte  Europe
I built speakers using the Ikea Blanda bowls (20cm diameter). After cutting the hole with a handsaw (slightly smaller than needed), I taped some sandpaper on the table and sanded till the hole had the correct diameter.
Just make sure not to apply to much pressure. I also sanded the top edge of the bowl to remove the rounding and thus have a larger glueing area before glueing the two halves.
The woodwork only (cutting and sanding) took me less than two hours for both speakers.
Old 2nd February 2018, 10:02 AM   #14
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Does glueing two Blanda's yield to a perfect bowl?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 4th February 2018, 10:56 AM   #15
wilbur-x is offline wilbur-x  Tibet
This is SB65WBA in an IKEA bowl/tube arrangement. Tube wrapped in brown leather.
A parallel notch circuit inside was necessary to make it smooth sounding. With a sub woofer is added, a full-body small speaker system will appear.
Old 13th February 2018, 10:37 AM   #16
hyped is online now hyped  Australia
Great work Wilbur
Old 14th February 2018, 03:12 PM   #17
audioaficionado is offline audioaficionado  United States
audioaficionado's Avatar
I'm looking at using the 8" bowls. Should give me just under 3L volume with two bowls and still fit on my desktop. Looking at using one of the small Markaudio drivers.
~Steve
IKEA Blanda Bamboo Bowl SpeakersHide this!Advertise here!
Ikea Blanda speaker, driver? oLjud Full Range 11 3rd August 2014 11:27 PM
ikea bowl speaker + CHR-70 gen.3 ma10 Full Range 39 26th June 2013 01:08 PM
Ikea Omni Bowl Speakers T101 Multi-Way 9 16th December 2011 05:28 PM
Ikea bowl speaker drivers polop1 Full Range 61 29th January 2011 08:38 AM
Ikea Salad Bowl 4" full range speakers chris12345 Full Range 22 6th January 2011 06:44 AM
