Construction Tips Construction techniques and tips
Screw & Glue Vs. Clamping?
Old 15th January 2018, 09:59 PM   #61
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It is confusing, probably what you would call particle board, like this Particle board - Wikipedia it comes in various densities though, some has smaller particles and is very hard
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th January 2018, 10:56 PM   #62
chrisb is offline chrisb
As our Welsh friend alludes, PB goes by numerous names, and like MDF it does range in quality.
We're currently working on a large volume commercial project for paneling and closet / office cabinets for a high-end condo project. The bulk of the project is in a fumed Eucalyptus veneer, sheets are 7ft x 8ft, and produced in Ecuador. Pretty enough face veneers - if rather dark - but the substrate is the worst non veneer core crap we've ever seen in the shop - smaller particles than OSB flakeboard, but the internal integrity is horrible once any machining made for dadoes, etc. Let's assume close to the standard 45lbs /ft^3 - a 3/4" sheet will weigh just under 160lbs, and those are architectural grade face veneers, so handling onto the beam saw and CNC, then several further production and finishing steps is "interesting"
like my mind, this space intentionally blank
Old 16th January 2018, 04:36 AM   #63
almstsobur is offline almstsobur  United States
Couple pics attached. Still waiting on tweeters and a few more crossover parts. Baffle is drying, so done for tonight, and work tomorrow Might be the weekend before it's finished.
Old 16th January 2018, 06:16 AM   #64
Do you guys break-in your drivers before instalation? I've got a frequency generator and plenty of amps, thinking about doing some break-in during my holding pattern. If you do break them in, what percentage of RMS power? How long? Do you fluctuate frequency, or just run at resonant frequency? Any point in tweeter break-in?
Thank You.
Old 16th January 2018, 06:54 AM   #65
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Despite some saying you should hit them hard, they should be played at low levels with varying source. I use a radio station and put at least 200 hrs on drivers before i start really breaking them in with real-world use.
An artifical signal can give the spider in particular a “bad memory”.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th January 2018, 06:57 AM   #66
Thanks Dave. I'm just going install and listen, keep the power moderate for a while. That's what I've always done with new purchased speakers anyway.
Old 25th January 2018, 12:48 PM   #67
Joel Wesseling is offline Joel Wesseling  Canada
Yes, various qualities of sheet goods available.
I don't purchase sheets from HD or Lowe's anymore.
Uniboard and Columbia Forest Products are two good names for MDF and Particle.
For a wall-to-wall TV cabinet, I used 3/4" Ultracore. Its a softwood plywood with thin layer of MDF on both surfaces. Plywood is light, stable, strong and hold screws really well. Surfaces are excellent for painting.
Old 25th January 2018, 05:10 PM   #68
+1 to the Ultracore / Procore types of products - although they're not as widely available through big-box chain stores - you'll need to check around for suppliers to the commercial trades
Old 24th February 2018, 01:28 PM   #69
chiily is offline chiily  United Kingdom
I've used biscuits and a biscuit joiner to make perfect, strong butt joints in MDF. Easy to get right with a little practice.
Garf.
Old 24th February 2018, 03:04 PM   #70
phase is offline phase  United States
Wood products from Canada is like coffee and cigars from the Dominican Republic!
The key to the laminated products is to get both sides treated the same, donít do that and the risk of warping is way higher.
My speakers are in therapy to help them with their bad memories...
Screw & Glue Vs. Clamping?Hide this!Advertise here!
Speaker front panel - to glue or to screw? quercus32 Full Range 6 20th October 2011 04:53 PM
Disk Clamping - Which is best ?? poynton Digital Source 32 1st January 2010 04:57 PM
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
Finger joints vs. screw and glue PRNDL Tubes / Valves 35 21st November 2006 12:24 AM
Glue or Screw? gchrist Multi-Way 40 19th July 2003 09:17 AM
