Construction Tips Construction techniques and tips
Drilling aluminum
Drilling aluminum
Old 29th January 2018, 01:58 AM   #41
stephenmarklay is offline stephenmarklay  United States
Originally Posted by vinylkid58 View Post
Without a drill press, you aren't going to get a nice straight hole, and it will be oversize, and slightly tapered.
jeff
I understand what you are saying. It is hard to get a straight hole without a drill press. It can be done with a bit of preparation just not as easily.
Old 12th February 2018, 08:39 PM   #42
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Use a 6” long bit and make a block of wood to stand next to it so it gives you an idea how straight you are as you drill.
David
Old 18th February 2018, 11:38 AM   #43
Jollygreenaudiophile is offline Jollygreenaudiophile  United States
Jollygreenaudiophile's Avatar
Drilling aluminum
The above is suggesting another improper federate which when coupled with the fact the set-up has no rigidity will equal intolerable tolerances.
If doing this by hand and you want accuracy?
1. Predrill center with dedicated center drill.
2. Drill thru with undersized bit "The next size smaller in whatever scale is being used."
3. Ream by hand using a hand reamer tool, cutting fluid and patience.
Or; Spend $25 at the local pawn for a drill press.
Old 24th March 2018, 11:36 AM   #44
speaker is offline speaker  United States
speaker's Avatar
38 posts regarding a ~0.014" material removal solution, we are freakin' doomed.
Old 24th March 2018, 01:36 PM   #45
Drilling aluminum
That'd be "DOOOOOOOMED!"
And no, I still cannot spell "federate". because this nifty pc keeps changing it to "Federate" And I am just too old to start spelling it "Feed Rate".
Old 24th March 2018, 01:36 PM   #46
Drilling aluminum
And this makes #46
Drilling aluminumHide this!Advertise here!
Advice on finishing raw aluminum.. keeping the aluminum look thehoj Construction Tips 30 29th August 2015 04:58 PM
TO-3 Drilling Jig BrianDonegan Solid State 17 11th January 2014 04:33 PM
Drilling aluminum mantisory Everything Else 53 21st November 2007 05:19 PM
drilling/tapping aluminum elizard Parts 32 6th March 2004 06:18 AM
