Construction Tips Construction techniques and tips
Drilling aluminum
Drilling aluminum
Old 1st January 2018, 12:11 AM   #21
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It is
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 1st January 2018, 12:13 AM   #22
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
No it's not.
jeff
Old 1st January 2018, 02:40 AM   #23
kevinkr's Avatar
Drilling aluminum
Since machine shop was mentioned it is likely the case they will charge you almost the cost of a cheap bench top drill press. You can pick one up from a local (hopefully) harbor freight for $40 or so. I have used mine to drill out dozens of knobs from 6mm to 1/4" without difficulty. I use isopropyl alcohol (70%) as a lubricant, it's not as messy as oil and leaves little residue.
I prefer cobalt bits, but HSS bits are good too, medium speed setting. Mount the knob in a chuck if possible, I don't recommend holding it as accidents can happen. Go slowly, even so the bit will likely grab and more or less rip the material out. (Still works fine)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st January 2018, 02:44 AM   #24
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Look at Rotobroach cutters. I use them for I/8 and 1/4 inch thick aluminum. I use their waxy lube too. Stocked at Amazon.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 1st January 2018, 02:57 AM   #25
phase is offline phase  United States
A very slow feed, and high drill speed will be your best bet, do this a lot, electronics less. A low speed will just grab. Some light oil wouldn't hurt, but should be ok without.
In order to spare the finish on the knob, I would use some pieces of wood against the vice, at least a rag if you can't get some wood bits. If you don't have a vice, or a means to hold the part, I don't recommend doing it really.
And to practice doing the same manuever a few times so you are comfortable golding the drill straight would help too.
Good luck!
Old 1st January 2018, 03:16 AM   #26
wayne is offline wayne  United States
Auburn
wayne's Avatar
Drilling aluminum
No problem done this many times. Lube with WD-40 not really a lube but works great to drill aluminum.
wizards assistant
Old 1st January 2018, 05:10 AM   #27
oohms is offline oohms  Australia
I'd just clamp it and use a battery drill. Use WD40 or even cooking oil as lubricant and you're good to go
Old 1st January 2018, 05:43 AM   #28
simon7000 is offline simon7000  United States
Take a 3/16" wood dowel piece 3" long. Cut a slit in one end 1/2" deep. Put a piece of fine sand paper 1/2" x 5/16" in the slot. Chuck the unsloted end in your hand drill. Carefully bend the sand paper over and insert into the knob. Run the drill a few seconds to polish the inside of the knob. Check for fit.
A machinist would chuck the knob in a lathe and mount a 1/4" end mill in the tail stock. That's right rotate the work not the bit. An end mill will cut close to square shoulders.
Old 1st January 2018, 05:45 AM   #29
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Also a very good idea and not as potentially damaging.
Old 1st January 2018, 07:33 AM   #30
Trollet is offline Trollet  Sweden
Trollet's Avatar
Drilling aluminum
A rotating file or a small milling bit are nice to adjust small holes.
The can be fitted in a hand drill.
A Dremel kit works well for such things to.
The reason for using lubricant in this case is that some aluminium alloys may stick to the tool.
Figge
Drilling aluminumHide this!Advertise here!
Advice on finishing raw aluminum.. keeping the aluminum look thehoj Construction Tips 30 29th August 2015 04:58 PM
TO-3 Drilling Jig BrianDonegan Solid State 17 11th January 2014 04:33 PM
Drilling aluminum mantisory Everything Else 53 21st November 2007 05:19 PM
drilling/tapping aluminum elizard Parts 32 6th March 2004 06:18 AM
